Gaming Car Mechanic Simulator 2021
So I recently upgraded to PS+ premium, cuz my renewal is in July, and it was only like $25 to upgrade for the remainder of my subscription, so I thought i'd check out and see what games became available to me. Car mechanic simulator was one of them (the original 2018 i think? version) and after playing that for an entire night, I looked up what improvements/additions were made to the 2021 version, and promptly purchased that.
For the uninitiated, in CMS21 you are as the title states, a car mechanic. when you start the game, you are presented with a ratty shop in which to perform your craft, a small amount of starting capital, and that is it. This is your palace.
And here's what you get to start. It's humble beginnings for sure. Why is there a creepy abandoned bus in here? No one knows. But you cant work on it, you cant drive it, and you can't sell it, so just enjoy looking at it for now.
Here is the back lot. It's not much to look at now, but as you level up and build up your bank account, you are going to have the ability to transform all of this with the addition of a dyno, car wash booth, and paint shop and test path facility for diagnosing pesky suspension/brake issues as well as performing suspension and headlight alignments. You can also eventually upgrade your shop as well, add a 2nd lift, and a complete add on workshop where you can refurbish used parts and body panels and make them new again, and you can also put an engine stand in there so you can completely remove engines to repair them (which comes in very handy), and you can also add a storage warehouse for storing parts! But you're gonna need to put in a lotta work to get there. :ROFLMAO:
Initially to earn your keep you'll take on randomly generated customer jobs, which start out fairly simple, but soon increase in their complexity, and there are also story missions you can progress through, but those are always more involved than normal jobs, and you better look at the description very carefully to make sure you understand what the customer is going to want before you take the job (more on that in a bit :ROFLMAO: ) Once you do level up enough, you open up other areas you can explore, like a HUGE junkyard where you can pick out loads of parts from countless piles of junk to bring back to your shop to refurbish and keep for future jobs, or to sell for some extra cash, plus you can find junked cars that you can buy so you can restore them and either keep them for yourself, or sell them for (hopefully) a profit. This is where the game really starts to open up
Similar to that, you also eventually unlock the ability to visit old barns that are randomly generated each time you go to one, and similar to the junkyard you can find parts and cars here as well. The quality of the parts and cars you find in here will be better than you find at the junkyard, and once you're financially stable enough (i cant stress that part enough :ROFLMAO: ) flipping barn cars is a way better way to make money than actually doing customer jobs. Most of them anyways.
So as I mentioned before, in the beginning, the only way to make money is by completing jobs. If you get overambitious with shop upgrades too early or taking on jobs that are more complicated (or both), you can get into......trouble :ROFLMAO: How do I know this? I took on a story job, and..............
Welp now I've done it. completely run out of money in car mechanic simulator right in the middle of a job :ROFLMAO: I knew I shouldnt have purchased that car wash booth, but this asshole brings me a car that looks like he took it thru the eye of a sandstorm and I just couldn't work on it like that. I didn't even know the car was blue until I washed it. But now I'm fucked. This job was way bigger than I thought it was gonna be. I'm gonna have to take another job and sell parts off that persons car just to finish this job, then shove that car in a corner and hope I can get back on my feet and maybe eventually get everything back for that car :ROFLMAO:
*2025 UPDATE* - The game is now available on all platforms, Playstation, Xbox, Steam, and there is even a VR version and a phone version, but.....eh. Also as of this time of typing, it should be available to play free on xbox game pass (*subject to change*)
sktchy
This sounds way more realistic than it should be, I'd definitely tank it
camarothatcould
I brings the ruckus
You must grab some screen shots of his horror show game. I know nothing of it
FINALLY finished that job up. It was a story job. Those are always more involved but I've never had anything like this before. Besides the usual mechanical repairs I had to replace pretty much all the body panels AND windshield from the A pillar forward. The dude pretty much admitted he literally crashed it thru a sand dune.
Here's everything I had to strip off some poor saps car just to get enough money to finish that job. I had to actually type everything up in a note file on my laptop so I wouldn't lose track of everything :ROFLMAO::ROFLMAO:
-gearbox (I4 RWD)
-starter
-drive shaft
-catalytic converter
-middle muffler
-rear muffler (V8 OHV)
-fuel pump
-front exhaust section (I4 SOHC)
-air filter base (I4B)
-air filter
-air filter cover (I4B)
-exhaust manifold (I4 SOHC)
-intake manifold (I4 MPI)
-throttle (I4)
-fuel rail MPI
-engine head cover (I4 SOHC)
-battery
-timing cover (I4 SOHC)
-alternator
-water pump (I4)
-power steering pump (I4
-crankshaft pully (I4)
-serpentime Belt (I4 SOHC)
-serpentine belt A
-idler roller A
-engine head (I4 SOHC)
-ignition coil (I4 SOHC)
-spark plug (X4)
-ignition wires (I4 SOHC)
-camshaft (I4 SOHC)
-camshaft cap (X5)
-radiator A
-radiator fan housing fan
-cam gear (I4 SOHC)
-timing belt (I4 SOHC)
-belt tensioner
Once I do a few more jobs and get back on my feet now this person is going to have a brand new car if I ever get around to replacing everything :ROFLMAO:
I'll see what I can do
camarothatcould DEEZUZ
Here's the outside of my shop
This is the poor saps car I had to almost entirely strip and sell his parts so I could finish the one main job I was working on, since I ran outta money..... He basically just brought this car in for a brake job :ROFLMAO: (we'll get to him later)
Here's the inside of my workspace, w/ my next job on the lift. Dont even remember what this one was brought in for
Here's where I mount and unmount tires and balance them
Here's the shop expansion i added on, which every guide will tell you not to expand your shop too quickly, which I of course absolutely ignored and lead to me running out of money in the middle of my last job
The purchases didnt stop there tho, as I also added.....
a lathe to turn brake rotors, which I have used exactly one time
And my wash bay, for when people bring me cars that have been buried in the ground.
And this is just a shot of the back of my lot
Now, getting back to the stripped car I currently have on my lot. I went over the complete parts list of everything I need to replace that I sold off his car, and it comes out to about $5500 :ROFLMAO::ROFLMAO: Definitely did not make that much selling all the junk parts off of his car. So I guess I'll be doing a few more jobs before I start replacing everything I stole off his car.
Was the first post moved from somewhere? It's a weird opening lol. However, I look forward to your adventures like in that other game.
Is it as glitchy as say farm sim?
Never played farm sim, but I haven't really encountered any glitches, yet
I started talking about it in the "what game are you currently playing" thread, and then it started to become more, so I broke it off into this thread
Soo easier or harder than my summer car? Have you pissed on anybody yet?
Definitely easier. This game kinda holds your hand actually. tho there is an "expert" difficulty that says it removes descriptions, and parts and bolts outlines. But thats about it. Yeah this is definitely not my summer car :ROFLMAO: There are no saunas, no firewood to chop, no booze, basically nothing that will kill you. Cars come in, you do the repairs, send them out, and bring the next ones in. I'm still not too deep in the game, but the eventual goal is getting your own project car and working on it. They do have barns you can find parts and cars in, a junkyard, car auctions, but again I'm not at that point in the game yet. You can also take cars out to a test track , and an air strip, and there's even a race track. I usually bring the nicer cars that come in to the track or airstrip. Especially if they just bring it in so I can drain and refill their fucking washer fluid. At that point I'm gettin my moneys worth out of the car before I give it back to the customer :ROFLMAO:
This 2021 version of the game does have electric cars too, which is interesting. I worked on one of those last night, had to almost completely disassemble the electric motor to find a part that was busted inside of it. That was an new experience for me
Maybe I’ll buy this then. I turned on my summer car for about 5 minutes a few weeks ago and decided I didn’t need that stress
Yeah this is like the COMPLETE opposite of MSC :ROFLMAO: this gameplay loop in this game is actually really satisfying as long as like you performing oil and brake changes over and over :LOL: The story jobs usually throw some curveballs at you tho. But so far the most stress I've encountered was being stupid and running out of money in the middlle of a big job :LOL: But I "solved" that problem..........
But just beware, because apparently credit lines do not exist in this game universe. If you hit $0, you gotta get creative.
Sprayin
Public Enemy #1
Grand Rapids, MI
I remember downloading this game a while ago and playing it once and never went back to it. I don't remember what about it didn't grab me, maybe I was just not feeling that type of game at the time. I still have it on my switch. Maybe I'll try it out again.
Edit: turns out the switch version is just a really bad port of the mobile version of the game, which sucks. That's why.
sktchy
I love that you made this a thread. But I'm still gonna have to fight myself on this one, I know damn well what I'll be doin when I should have a real scanner in my hands :rofl:
Took in this NOT A TESLA for a job.
Lets see here, CUSTOMER STATES:
- The engine has no power. ( :ROFLMAO: well I think I already know what yer problem is)
- Vehicle cannot be started
-Suspension Rattling
-And a request for "general running gear control and repair" for which the customer actually provided the source of that issue, which was the double wishbone shock absorber.
The rest, I would have to figure out for myself.
Quick PRO TIP! : Things you should actually invest in as early as possible: compression tester, multimeter, and OBD scanner.
Couple quick scans gave me a couple quick answers. For the source of vehicle cannot be started, it happened to just be a relay in the fuse box, so that was a quick fix...once i actually found the fuse box :ROFLMAO:
Yeah I don't think i need a scanner to see what the problem is here.
That turned out to be a cable, and a power electronic controller. And there's actually a lotta shit inside that box you gotta take out before you can remove it :ROFLMAO: All better.
Now for the suspension issues, Here is the aforementioned double wishbone shock absorber, as well an outer tie rod that has seen better days.
And on the drivers side, I found this sway bar endlink was definitely a bit shot
Replaced all those, and viola!! good as new car, which I immediately took around the race track for a "test drive" and is now the current record lap holder for cars ive "tested" so far :ROFLMAO:
Had to take this job in because.............
well because Supra
customer states: (and he actually provided a detailed list of what needed replacing. I love these kinds of customers)
tapping sound from the engine bay
Replace:
-Alternator
-clutch release bearing
-exhaust manifold
-crank bearing cap
-flywheel
-water pump
timing needs replacing
Replace:
-belt tensioner
-water pump
-water pump pulley
yeah definitely see some not so good stuff there
trans removed, yeah more bad stuff in here
for the crank cap that means oil drained and oil pan off.
There she is.
Everything replaced and all better!
Promptly took it out to the race track. :ROFLMAO: It did not beat my Tesla time.
I've been busy.
Got a pretty good payday from a story job, as well as some other normal jobs that had some decent payouts (i only tend to look for jobs now that have money or XP bonuses) so I of course ignored all logic again and splurged on some more shop upgrades.
Added a storage room for spare/extra parts to keep them out my normal inventory. I've made a few trips to the junkyard now, and it is HUGE and has tons of piles of shit you can rummage thru. I actually found a FEW pieces I needed to replace on that car I stripped everything off of :ROFLMAO: Plus a couple other random parts I picked up that were in pretty good condition, just in case I ever need them down the line
Added a workbench area to repair body panels, tho I haven't been skilled enough to repair anything yet :ROFLMAO: Right now I'm dumping all my skill points into the Renovator tree (which is what you need to repair shit) so I'll work on maxing that out before I think about other skills)
Also added a workbench for repairing mechanical parts (tho again, haven't had the right skills to actually fix anything yet)
And the big one. Added a paint booth! But this one was actually kinda necessary for the next story job I was about to take on
Because this is what got brought to me. Some dumb kid borrowed his dads "M3" and did some dumb shit with it, and now he brought to me on the DL so I could fix it for him. :LOL:
I read in the initial overview I was gonna have to repair or replace body panels, and repaint the car (hence the paint booth), plus a bunch of other shit that went wrong, and looking at the body, I figured EVERYTHING was going to have to be replaced, so I stripped every panel and piece of glass off the car, plus pretty much had to remove the entire rear passenger suspension because it was all just trash
BUT then I actually looked at the work order, and found out he only wanted me to replace the front and rear bumper, a front headlight, and the front fenders :ROFLMAO: So, did all the mechanical work first, bought the body parts he wanted replaced, slapped it all together, and......ready for paint i guess?
Done! CANT EVEN TELL anything was wrong! :ROFLMAO:
I need to buy a welder next because that allows you to do full body repairs, which probably would have come in handy here, but he didnt request it so screw him!
Other things, this "Skyline" came in for some work (cant remember what) and it was looking quite ragged
But surprisingly the engine bay was UHMACULATE. Who woulda thought
Also finally made a trip out to the car dealer, saw this nice bright yellow camaro in the showroom w/ AZ plates. Think it was like $140k or something ridiculous like that. Looks like my first car is going to have be obtained thru the junkyard or a barn, which speaking of, I am also finally level 10 now, which is what you need to be to unlock the barns! So it might be time to start seeing what I can dig up.
Im somewhat comfortable w/ cash right now, so maybe it's time to put that shmucks car that I stripped for parts back together and finally get it out of here. It's served its purpose :ROFLMAO:
