so, got to dig into a V8 for the first time in the game so far
but dont get excited. I pulled it out of this.
And as you can see, quite a few of the rocker arms are fucked. As well as many of the pushrods. And that's not all. This was a story job, and while I knew from the overview it was gonna be a lotta work. I had no idea
There were a few pistons that were fried, and EVERY single piston ring in this engine was toast.
As well as the crank, crank caps and more than a few rod caps
After I tore everything down the to bare block, this was the shopping list I ended up with
And that doesnt even include the fuel filter, fuel pump, starter, alternator and serpentine belt I had to replace first JUST to get this motor in good enough working order to do a compression test on it, which is when I discovered all the internal damage.
But I carried on, got the new parts, and reassembled everything
Dropped it back in the van, checked my completion list, and thats when I discovered it was still saying i had 2 bad pistons, 2 bad rod caps, 2 bad pushrods, and a bad spark plug........WTF. I think what happens is, with every job, the customer has a required level of parts quality they want everything replaced with. So if they want parts that are at least 58% good, thats what you have to replace all the bad parts with, but I THINK they have to be replaced in the same spot you took them from. So if you take all the pistons out, even if you replace it with another piston from that engine that's still "good" technically, if its not at least 58%, the game wont count it. And the other problem is, you can't tell when you've replaced something correctly if its not actually IN the car. So you can build a brand new engine on the stand with new everything, and if you check the completion list, its not gonna show any of those as being completed until the engine is back in the car.
so I had pull everything back out AGAIN, and then try and mix and match parts while rebuilding the engine inside of the van to see if I was replacing the right parts. Fucking hell. I really need to start taking pictures of this shit as I'm disassembling stuff so I can remember where the good parts are supposed to go back
But that's not all!! That all was just to get the van running so I could bring it over to my test path so I could diagnose the multitude of brake and suspension issues that this van was ALSO suffering from. And there were many. Every corner of this thing was fucked.
All said and done this was my shopping list for all of that shit. I think nearly every fucking bushing on this thing was shot
And after all that, it really even wasn't THAT great of a payday, especially for all the shit I had to deal with. But hey whatever. Its a living.
Also added this salvage container to my lot
I really don't know what the hell it does, but it appears there's another type of "currency" you can build up by salvaging old parts, and you can then use that currency to upgrade other parts. Which doesnt really mean anything for the day to day work, but it might come in useful once I start building my own car. So instead of selling all the old damaged parts I tear off all the cars for pennies on the dollar, i'm going to start salvaging them all now and building up my salvage currency.
