Busted....... (Cobra content)
MrMezger996
Formerly CobraSki
3,047
3,383
Hoffman Estates
Well, I finally headed to the track for the first time with this car. I wanted to get a base line before the F1-A and other goodies go on. I made my first pass, terrible wheel hop, 1.8 60Ft. Decided to add some tire psi is hopes to get ride of wheel hop. I haven't done anything to the IRS, and well it grenaded on my second pass. Now do I stay IRS with some DSS half shafts, new carrier and FTBR kit (which I have in my garage just haven't installed) or so I go 8.8 SRA??
118,964
You can. Definitely. If you're looking to keep the car more lively on the street, get that full tilt kit on for sure. I don't know if you'll need the dss axles. I know some guys just keep spare axles around and become really good at changing them out in a pinch.
Boostie
2,853
4,140
I cant say I race the most at the track but so far has not let me down at the track and lots of street abuse. Out back the car has
Driveshaft Shop Level 5 halfshafts
Viking Double Adjustable Shocks
Full Tilt Boogie Racing Rear Bumpsteer kit
Steeda COBRA IRS differential brace
Steeda IRS subframe reinforcing bracket
Steeda IRS urethane subframe bushings
Steeda urethane rear IRS control arm bushings
Kenny Brown urethane IRS rear differential bushings
Kenny Brown rear steer kit
Russell stainless steel brake lines
SP Performance drilled & slotted rotors
Hawk HPS Brake pads
Eibach Springs
MrMezger996
Formerly CobraSki
3,047
3,383
Hoffman Estates
Hawk HPS Brake pads
Eibach Springs
Well the parts I have in Garage collecting dust is FTBR complete bushing kit with Housing cover, MM IRS brace. I already have MM Coil Overs, and now I'm ordering DSS Level 5 half shafts. I haven't gotten car in the air yet but I'm hoping I didn't crack housing. Car still rolls, so Ring and pinion I'm assuming is stillnok still good.
Boostie
2,853
4,140
Tires have a lot to do with it too, I always hate making passes on my street wheels because the lack of sidewall seems to bring on more wheel hop if not launched just right. If you plan on doing a lot of racing a bias ply tire will be much more forgiving on a stick IRS car.
MrMezger996
Formerly CobraSki
3,047
3,383
Hoffman Estates
I haven't gotten underneath car yet, I will tmrw but I have to assume I broke a half shaft. Immediately after slipping the clutch heard a pop and car went no where, it didn't happen during any sort of wheel hop. I can see grease flung around like the half shaft boot tore up. Maybe the case cracked, or diff cover cracked, but had no gear lube spilling out.
