Boost Gauge Help
-=SVT=-
Gold Member
I bought a boost gauge and wanted to know if any of you did there own! If so were do you connect the new boost gauge to? I got an Phantom auto meter and it gave me shit directions. I have no idea were it connects too on the engine! :dunno: any help would be great Thanks
Brian
01Sleeper
You can connect it to any vacuum line under the hood, or I believe there is a line behind the glovebox you can T off of.
Brian
Mr03Cobra
612rwhp - 590rwtq
Run vacuum line thru firewall under hydro booster.
I Teed mine off the Boost selenoid. Looking at the Eaton from the driver side, you'll see all the selenoids, etc.. on a bracket mounted to side of Eaton. Far left one toward front of car. Tee off that vacuum line connecting to that selenoid. I used a piece of vacuum line from auto parts store to end of plastic line off guage & slide that hose onto the Tee you'll get from auto store. You will need a couple inches of the line that connects to selenoid to fit from the tee to selenoid.
Not a bid deal. I have my Whipple set-up that wat too.
-=SVT=-
-=SVT=-
Gold Member
So i have to use a T fitting for the lines vacum lines on the engin if i go there?
01Sleeper
Yeah, you can choose any vacuum line you want and just cut it and put a T in. The guage should have come with various fittings.
-=SVT=-
-=SVT=-
Gold Member
Well it didnt come with a T fitting but i can go buy one. Thanks for the help :biggthump
01Sleeper
No problem. I would also put some zip ties on the end (to act as clamps) I had a small leak at first, but the ties fixed it.
-=SVT=-
-=SVT=-
Gold Member
I went and bought a 1/8 Vacum T and the tube is just way to hard. it wont go on. It looks a c hair biger then the tube but the holes are the same size. :dunno:
01Sleeper
You will need to slip a small miece of vacuum hose over the end to use as a coupler. There is probably enough slack in the line you cut to use a small piece.
-=SVT=-
-=SVT=-
Gold Member
Yea but i cant even get the tube over the fitting the tube is 1/8 and the fitting is 1/8 it just dont slip on.
01Sleeper
You shouldn't need to slip the tube onto the fitting. Just slip a piece of hose over the tube, then the other end of the hose onto the fitting. So when you are done, you will have three pieces of hose on your T.
-=SVT=-
-=SVT=-
Gold Member
OK :clap: i got you, it took a bit to get. I am slow today. Thanks i will try that!!! :p
imported_04 cobra
i just did mine and there is a yellow hose on the ps behined the glove box. you can tie off that, their is no cutting needed.
rocket5979
Gearhead
Round Lake, IL
Just go to an Auto Zone or Pep Boys and they should have a little kit box that has all sorts of vacuum tee's, y's, and couplers. I also bought the vacuum cap box too and the rubber couplers also. I have used those few boxes for all of my custom vacuum routing needs. I do not foresee having to buy another vacuum part for a vehicle for quite some time. :biggthump
Mr03Cobra
612rwhp - 590rwtq
Easy trick, wet the ends of the Tee's with your mouth, the hose will then slip on. It is supposed to be a little tight like a virgin, keeps it from popping off when boost runs thru it.
