auxilary fan always runs
Burt Ragio
Shortly after warm up my auxilary fan starts to run & switch back & forth between the two speeds. The motor does not over heat. I never remember the auxilary fan always running so much. Almost acts like coolant is low. I have checked coolant level & it seems ok. This happens with nothing on no A/C no defrost no heat. Outside air temps have been around 50-60 degrees. What should I check ?
fastblackmerc
Auxiliary fan? If you mean the radiator fan, the first thing I'd do is burp the cooling system.
Zack
4 Doors 4 Life
NW Indiana
You wont have a difinitive answer until you hook a scanner up and read actual coolant temps.
Is the air being pushed by the fan cool or hot?
