Originally posted by Ron Vogel@Nov 11 2004, 12:09 PM
They need to be specific for E85 fuels though. The FFV's are completely nickle plated.
[snapback]60018[/snapback]
The 25.3's are rated at 43 psi, so theoretically running them at or around 60psi will raise the ceiling quite a bit, and improve atomization. There are no hard facts out there I can find to fall back on, but with boosted pressure and wide pulsewiths, it is my humble opinion that the 25.3's should support up to 400hp at a 1 to 3 ratio of alky to gas.
What kind of ideas did you and Justin talk about?
On the HP tuner's wideband version, there are 2- 5v outputs, one of them could be configured to run an injector driver.
Justin really likes the idea of doing a 7th injector, and injecting fuel at the inlet of the SC. It won't have as good as an effect on cooling, but will still cool. A breakout box is still required, but the pump/regulator are a non-issue, because it can be fed by tapping the rail. Some of the turbo Buick guys have had some good sucess with this. I have a feeling something like this mimic's a accelerator pump on a carbed car, so atomization of the fuel during injection isn't required. The large gas droplets will generally not combust, and stay liquid all the way out of the chamber (for the most part). Something like that would really help with part throttle, and transitions to WOT.
Originally posted by superchargedgp@Nov 11 2004, 04:41 PM
so you guys are using alcohol injection with the intercooler?
whats the point? isnt i/c itself enough?
[snapback]60071[/snapback]
I'm too lazy to port my heads, or put in a cam. With the alky, timing, and more boost I'm estimating 40 hp. I'd like to run max timing with a 2.6 pulley. I'd rather throw the big money mods at the trans; where it'll make the most difference for my car at this point.Originally posted by superchargedgp@Nov 11 2004, 04:41 PM
Thanks, I may hit him up if I run into snags. I've got my FFV injector on the way, I'm getting a Shuflo "Blaster" pump (45psi) this weekend, and I should be breadboarding the circuit this weekend. I have something that will follow boost up to 15 psi, then shelf off. Turn on will be around 4-5psi. Only problem, I may need to set this up so the user needs to swap injectors to meet engine demand. Everything else will be plug and play. Fortunately, induvidual injectors are cheap (no more than $30). The most expensive part of the system is the pump, which Farm and Fleet carries for $64.00 (and online prolly cheaper). I could always build another PWM circuit to control pump speed to regulate flow, but only if it needs it.Originally posted by Caedo@Nov 29 2004, 04:49 PM
Ron you should talk to FlyingGTP AKA Mike he actually looked into this like two years ago and had the system running in his car i can vouch for that.
Juan
[snapback]61692[/snapback]
Originally posted by RoyalGTP@Dec 2 2004, 12:33 PM
MIke K,
What injectors are you getting? LB size?
[snapback]62060[/snapback]
I'm spraying before the SC. I have no teflon left so I don't really care too much about it, although from what I've read you really only have to worry about that with 100% alky. It'll do a better job bafore the SC, it keeps the rotor temps down, and since alcohol is a base, it's slippery. It'll actually help lubricate.Originally posted by sweetness+Dec 4 2004, 02:29 AM--><!--QuoteBegin-RoyalGTP@Dec 2 2004, 12:33 PM
MIke K,
Im curious where you plan on sprayig? A few people have done this by spraying before the S/C. They started to see their teflon coatings peel off. the benefit of course is that the S/C gets cooled down.
If it were me doing this I would put this spray after the intercooler. I have reasons for doing so, but its 2:30 in the morning and i cant construct the thought to type it out. Ill try to remember to reply tomorrow.
BC
[snapback]62362[/snapback][/b]
MIke K,
BC
