96 Pontiac Bonneville
price is $1,000 OBO
it is a 96 bonneville with 130k ish on the clock, AUTO
-gold/bronzish exterior with tan Leather inside
the good:
-engine runs with no problems, Lower and upper gasket were replaced less then 10k miles ago, it has new plugs and fresh oil. new fuel regulator
-Suspension is in good shape with no real problems.
-Interior is in pretty good shape (no rips or tears in leather)
The bad:
-Trans sometimes (doesnt happen always) will shift a bit hard, it might just need a fluid change and some lucas, it drives fine and doesnt slip, has power throughout the rpm range in any gear.
-Exterior is a bit beat up, needs a new pass. mirror and has a good size dent on the pass door. Door closes fine with no problems and window works fine. -No rust other then very little spots on the rear quarter panel.
-Left rear Tire has a slow leak
-Brake fluid MIGHT leak from master, but i havent verfied that, it could have been just low on fluid. UPDATE AT BOTTOM
-Needs a balancing on the tires, steering wheel shakes at 75 and up
i drove this thing back and forth from isu with no issues, i figure it will be a decent DD if someone were to fix the blower, i know most of the guys here are 3800 fans so they might know more on what to do with it, I just want it gone :)
Make me an offer!
