96 Pontiac Bonneville
price is $1,000 OBO
it is a 96 bonneville with 130k ish on the clock, AUTO
-gold/bronzish exterior with tan Leather inside
the good:
-engine runs with no problems, Lower and upper gasket were replaced less then 10k miles ago, it has new plugs and fresh oil. new fuel regulator
-Suspension is in good shape with no real problems.
-Interior is in pretty good shape (no rips or tears in leather)
The bad:
-Trans sometimes (doesnt happen always) will shift a bit hard, it might just need a fluid change and some lucas, it drives fine and doesnt slip, has power throughout the rpm range in any gear.
-Exterior is a bit beat up, needs a new pass. mirror and has a good size dent on the pass door. Door closes fine with no problems and window works fine. -No rust other then very little spots on the rear quarter panel.
-Left rear Tire has a slow leak
-Brake fluid MIGHT leak from master, but i havent verfied that, it could have been just low on fluid. UPDATE AT BOTTOM
-Needs a balancing on the tires, steering wheel shakes at 75 and up
i drove this thing back and forth from isu with no issues, i figure it will be a decent DD if someone were to fix the blower, i know most of the guys here are 3800 fans so they might know more on what to do with it, I just want it gone :)
Make me an offer!
RICH17
Dr. Pussy Slayer, MD
26,707
1,992
The 007
Adam Rich
Fuck I forgot that. Honestly its a parts car then. I'd call victory and ask them to pic it up. They wont give you much in anything to get it without a title. I'd take it if it had a title and use it for a winter beater but no title is the pita. It took IL 4 months to get me a title for my firdt Lumina back in 2006 as well.
Lord Tin Foilhat
60,686
56,744
Privy Chamber
$100 bucks. Parts only. If you want a title I can help you get it with a death cert. But don't have the time to go to the DMV.
The front has oil on the exhaust manifold. Looks like its one of the gaskets. Smokes cause its burning it away. Runs good for now but unsure how reliable it is. No brakes except ebrake works
If nobody wants it I'm junking it this weekend. I need it out of the way for the projects I actually care about
