That is what I’m using too. I put it in a ziplock with desiccant packets thinking maybe it absorbed water. Haven’t tried since. The hotend has been great otherwise, also got a screw in thermistor from the same company. Gulf robotics I think?
I was looking at Triangle Labs.That is what I’m using too. I put it in a ziplock with desiccant packets thinking maybe it absorbed water. Haven’t tried since. The hotend has been great otherwise, also got a screw in thermistor from the same company. Gulf robotics I think?
gotcha. I will be using Nylon (trimmer line) for the cold pull most likelyno. all you have to do is remove the bowden so you can grasp the filament n carriage and pull firmly.
your probably fine to just hand feed during the void purge/cooldown.
with pla i start to pull at around 60c when my hownd fan startsup. the plastic will heatup towards its core and you stretch it which pulls it in from the sides and out she comes. sometimes with pla it'd snapoff at the heatbreak zone....none so far with petg, its just so stringy
All my stuff is in dry boxes with desiccant packs and I print from the dry boxes. If they arent in the printing dry boxes, they are in ziplocks with desiccant and then put in a plastic box with more desiccant. I dont think moisture is my issue
I’m under the impression you can’t do one with the stock boarddo a pid learn. if its an exact replacment it might be fine but id still do it
you can, you just need to hook it up to a computerI’m under the impression you can’t do one with the stock board
what material?any ideas on this? I stopped the print bed adhesion seemed good.View attachment 67712
try to run a PID Tune for the hotend.Hatchbox PLA. been printing real decent before. wondering if it got cooler and that started causing problems. I had a 200w bulb and an enclosure with the door open.
I am making as case for my raspi.
