is it the true skr 1.4? the skr 1.3 was fucking garbage i kinda want a board upgrade for marlin 2.0 without being stuck in the MKRBS robin nanno tree branch with its limits.
but if i do that ill probably go duet. them brits sure got that shit on point, plus 2.8 amp drivers
quick suggestion everyone.....its time for a heater PID learn....
at this point im going to suggest that this is something for you to REGULARLY do.
its also a harbinger of things to come if the parameters vary from your previous PID.
deffinatly do it even if you ONLY service it and the heater and thermister were even looked at.
the PID learn helps keep ya from overshooting the temp (heater hysteresis) and holy fuck do small changes really screw with odd things, line klayer hernia's at overhangs, traverse bubles/filament cooking.
dont forget that after you input the new Kp, Ki, Kd via the M301 make sure you M500 to save into the firmware if you dont manually edit config.h
bed heater doesnt seem to have as much variance but writing the values down and testing every now and then might tell you when one of the heater circuit paths might burn out (those of us with bed blankets cant readily look at the heater pad)
i will tell you this much, just having plastic "wick" into the heater pill area changed my values.
ive also gotten a little farther with the electronics backpack for the "little" printer. still have to setup the power supplies but the pi4 is setup as a master temp monitor/kill with octoprint and is completely stand alone with a contactor to kill the power and or trigger the nitrogen flood extinguisher (300+c for polycarbonate).
this is meant to easily transfer to the "big" printer as we assemble and test its systems over the next 10 years
