Your probably referring to the Max Jack by Danmar.
Hmmmm interesting. My main reason for not going with a MaxJax was at full height it's still to low to stand under but to high to lay on a creeper. It's really nice for wheel and brake work. Plus I wasn't a huge fan of the main support of the lift being the quality of the concrete.
Bringing this thread back from the dead;
About 2 seconds away from pulling the trigger on a QuickJack as my Birthday present from my wife to myself.
[MENTION=12096]CobraSki03[/MENTION] how are you liking yours? Reasonably easy to move around?
[MENTION=85]EmersonHart13[/MENTION] did you ever pull the trigger on one?
sorry didnt read you asked about moving it around.....
So I store mine along side my garage and stack each lift on top of one another. I mounted the pump to wall in garage and the hoses disconnect easy with the quick connect fittings and dont leak which is a plus. Only thing I have had to do was check the air pressure and maybe add 1psi to cylinders as that is what help lower the lift. I ended up buying the rubber blocks that have the cut out for the pinch welds as lifting car at the frame was alittle in the way of the exhaust, so moving out towards pinch welds solved that. I left car up on lift for one week zero issues, and the locking bars really seems sturdy and strong. I was alittle nervous getting under car at first but after lifting to first safety lock and pushing side of car and checking for stability that quickly went away.
The pinch weld blocks aren't even forsale yet on QuickJacks website? I assume you bought them from someone else? Link?
Welp, I just ordered the 5000 along with the SUV adapter plates.
Excited to get it and try it out!
So my sales video worked???? lol
Its arriving on Friday; I'm beyond stoked.
The Exploder and Mustang both need some attention, can't wait.
Well where are the picks of the exploder on the quickjack!!!
