Cadillac CT6 V Sport - 550hp / 627tq
118,964
:eek3:
What's under the V-Sport's probing hood is just as interesting as the redesign and the sporting thrust: A clean-sheet design of a 4.2-liter DOHC twin-turbo V8. In the V-Sport, the engine produces 550 horsepower and a Bentley-esque 627 pound-feet of torque. As an optional engine elsewhere in the CT6 range, the same engine produces 500 hp and 553 lb-ft. The displacement, specs, plus the fact that "each engine will be hand-built at the Performance Build Center in Bowling Green, Kentucky" indicate this was one of the rumored powerplants for the mid-engine Corvette. The coming sports car was tipped to get a 4.2-liter and 5.5-liter DOHC twin-turbo V8. Based on the position of the turbos in this engine vs. their positions in the previous CAD drawings, we assume the drawings represented the 5.5-liter.
The 4.2-liter item features an aluminum block, heads, and pistons, direct injection with a 9.8:1 compression ratio, cylinder deactivation, cylinder oil jets, and a variable-pressure oil system. The twin-scroll turbochargers capable of 20 pounds of boost sit in the 90-degree vee, working alongside twin water-to-air intercoolers, twin throttle bodies, and twin electric wastegates. Cadillac says 90 percent of torque arrives at 2,000 rpm and loiters through 5,200 rpm. Power gets sent through GM's 10L90 ten-speed automatic transmission and on to the standard all-wheel-drive system.
https://www.autoblog.com/2018/03/21/cadillac-ct6-v-sport/
