Since most conventional ovens don’t go below 175 degrees F, we usually cook chicken by blasting it with heat in the hopes that we can stop the cooking just as the inside reaches 165 degrees F. The problem with this approach is that by the time the center of the meat hits a temperature of 165 F, the rest of the meat has blown past that number, resulting in the core temperature rising further due to the residual heat. That’s why most recipes will have you pull the chicken out of the oven after it reaches 160 degrees F, which factors in about 5 degrees of additional cooking from the carry over cooking.
If you’re confused, I don’t blame you, cooking chicken breast in a traditional oven is a bit like going duck hunting with a slingshot. Put simply, chicken breasts aren’t well suited to being cooked via traditional methods. So how should we be cooking chicken breasts?
Well, let’s first take a look at the reasons behind the recommended internal temperature of 165 F for chicken. According to the USDA, salmonella is killed almost instantly in chicken at temperatures above 162 F. By setting the guideline at 165 F, they’re giving a conservative number that’s easy to remember and accounts for variables such as the fat content of the meat and inaccuracies of thermometers. Like most things in nature though, killing pathogens isn’t so black and white.
Killing pathogens isn’t just about temperature, it’s also a function of time. For instance at temperatures above 162 degrees F, Salmonella is destroyed in under 10 seconds, at 150 degrees F it takes 2.7 minutes and at 136 degrees F it tastes 63.3 minutes. So in theory you could cook chicken to 136 degrees (which is the equivalent to a medium rare steak) and provided you held it there for long enough, it would be just as safe to eat as an overcooked piece of chicken registering 180 degrees F.
But with traditional cooking methods, holding chicken at a low temperature for such a long time would have been next to impossible, and certainly out of the reach of most home cooks. This is where cooking sous vide really shines. It’s a technique that allows you to cook food in a waterbath that’s held at a constant temperature. This allows you to cook difficult foods such as chicken breast safely and predictably, which is why the technique has become so popular in restaurants kitchens.
Read more:
Sous Vide Chicken Teriyaki - No Recipes
All images and text on this website are protected by copyright. Please do not post or republish this recipe or images without permission. If you want want to share this recipe just share the link rather than the whole recipe.
