[MENTION=340]Eagle[/MENTION] , I would explain about your suspension woes . Or maybe it was your hubs ?
Op , if there is any chance , try to find out when the last high pressure pump was replaced or if the injectors have already been done . Also would check for oil around the c.a.c clamps. And check to see what the coolant looks like or smells .
The other easy way to see if you getting any glow plug draw is to watch the gauge on the dash at key on engine off . Or go check right off the battery with an voltmeter . It will pull the voltage down. You won't know the amperage , but you'll see a voltage drop . This would be best in cold Temps to see though.
Still has the original HPOP and injectors. They cleaned the engine bay, but the lower coupler on the passenger side showed some oil. The coolant is clean. It was flushed a year ago. I'll still flush it and put in a filter.
But, we are still a ways apart on prices, so IDK if this will happen.
