v6buicks
6,373
15,820
Franklin, IN
Jon
So, after some research, it's universally known that the nylon hose autometer gauges comes with are crap. So I guess most people just put a 1/4" barb nipple right on the gauge and run a good hose.
Did your research involve seeing the last post in my build thread? ? Yeah, that nylon tube is a bad idea.
GTPpower
6,352
9,752
Nebraska
So race day is in two days, and here the car sits....
I decided that since we have nice weather this week, I'm better off putting a new roof on my house. So that's been taking all my time.
But, luckily, the car is basically ready to go. I just need to fix the boost gauge vacuum line, pull the plate off, and I can load it on the trailer. I know it wants more timing, but I'm hesitant to throw more in without knowing how much boost it will actually run with no leaks.
Just go throw some timing at it and do a few street hits before race day
Reactions: sktchy and GTPpower
sktchy
7,758
12,043
Least yours has a motor in it lol, I wanted to be ready for this weekend but I've spent the last two days fighting sewer issues and might try and start dropping the k out tonight. Not that it wouldn't be my style to trash it together in short order to go break it again.
Second a couple street hits tho, pour a lil sticky down and see what ya got before throwing the beans to it and ending up like mine lol
Reactions: GTPpower
GTPpower
6,352
9,752
Nebraska
Got my new fitting for the boost gauge installed.
Fixed all the crappy plastic tees.
She's pretty much done.
It holds boost pressure for a couple minutes now and I can't find any leaks, so I'm guessing it's just from getting by the rings and maybe the exhaust valves.
I drained the fuel tank..... absolutely soaked myself doing it. But it's got fresh e85 now.
I'm planning to head to the track for t&t tomorrow, but I'm still not 100% if I'll go.
GTPpower
6,352
9,752
Nebraska
Maybe someday I will add a tube for a fresh air inlet, but more than likely a turbo will go there instead.
So, I finally got tired of sucking ice into the pump inlet hose, so I put a screen over the inlet.
I'm at the track. Nice day....cloudy, mid 60's for temp. I'm not hooking well, and the car is running like trash. Did two passes so far....12.5 and 12.6 both at 106mph. I'm getting 4-5 degrees of knock maybe 1 second after it shifts into 2nd gear. But this thing is not even building 10 psi now. What the hell. I fixed about 50 boost leaks, some huge, and it's making less boost than before.
M90's are dumb.
