GTPpower
6,295
9,611
Nebraska
So after about 15 tries, I'm finally air tight. Maybe the world's first boost leak free l67 tb over 20 psi.
Now, the thrasher nitrous TB plate has a leak right where the 1/8" npt plug is at. It must be thin and deforms easy or something. I think I will get a gasket and put rtv on both sides to try and seal that up.
But, I just need to wash everything up and put it back together.
GTPpower
6,295
9,611
Nebraska
I was able to get a little work done today.
I'm planning to change the fuel supply lines up a little to make them look cleaner, but that will have to wait for another day. I did add some heat shielding to the main harness that runs across the engine since it basically sits on the lim. Hopefully I can get it running this week. I need to get a couple of oil filters since I always change the oil a couple times right after pulling the lim.
GTPpower
6,295
9,611
Nebraska
Yeah, we will see what happens. I've seen people use hose clamps before with good luck. But, for whatever reason, I don't think this clamp worked correctly before. I remember something about it felt goofy when I put it on. This one definitely felt better. I just wish my straps had the little ears to hold the excess strap down.
Reactions: sktchy
GTPpower
6,295
9,611
Nebraska
Street car night is Sept 11th. We're a little over a month away, so I need to get rolling. It would be nice if I can actually get the car together early enough to do some tuning on it before track day.
Axle revision 2 is back in with a new oil filter.
For whatever reason, I really enjoy making fuel lines.
Maybe it's because I get to use my wife's pink screwdriver.
Fuel lines all finished. I was going to wrap them in heat shield, but I don't think that's necessary now that I see how they are routed.
GTPpower
6,295
9,611
Nebraska
It's up and running. I had a bad misfire on #2. I would let it run for 10-15 seconds, which was enough to build up 50-100 misfires. I swapped plugs, wires, coils, and quadruple checked all my connections. Spent a ton of time on that, and nothing changed.
So, I was about ready to get the compression gauge, but decided to hold the rpm up for a bit to see what happens. Misfires mostly go away over 1500 rpms, but it has completely changed. #2 shows nothing now, and it's 1,3,&6. Nothing severe, but something to watch I guess. Maybe it's a sign or a failing icm?
Anyways, oil is drained and I'm waiting for it to cool a bit to try and suck some coolant into the block, but I think it's bled pretty well.
Reactions: sktchy
GTPpower
6,295
9,611
Nebraska
Yeah if your lifters are collapsed from sitting it might take a little bit with oil pressure to fully pump up especially with old lifters
I think that might be it. It seems to have worked itself out. I guess I should have just let it run a bit longer and I would have saved myself a bunch of work.
I put oil back in and took the kids for a little ride down the street in front of my house. I stabbed the throttle lightly.....the jury is still out, but the bov seems to be way louder.
Reactions: TurboTPI
