v6buicks
6,379
15,840
Franklin, IN
Jon
Maybe I'm doing it wrong, but I don't really think that's necessary on aluminum. It gets so damn hot after only a few seconds of welding.
Preheating it will not only help work out the impurities, but it will allow the temp to rise gradually versus being shocked with the torch. You also get the advantage of the whole part expanding at the same rate. This prevents cracking. It's always weird for me to think about this with aluminum because it's already such a heat sink by nature, but certain castings can change everything. I went down this rabbit hole when I converted my FWD manifold for RWD. I actually didn't even do the welding myself, so I'm just relaying what I was told. I handed it off to my work buddy who does this stuff pretty regularly. He still struggled like hell to weld it without leaks. Long story short: these manifold castings can be kind of a bitch. lol
Is the pipe counter sunk at all or is it just butting against the manifold? I think sinking it would make welding a lot easier too, but it would be a lot of work at this point.
Reactions: GTPpower
v6buicks
6,379
15,840
Franklin, IN
Jon
I really don't think I'm any better, the welding area is just cleaned much better now. I'm removing material with the die grinder now versus just touching it with a wire brush last time.
Using a stainless brush that's used ONLY for cleaning aluminum is a good thing too. I've accidentally used my "everything else" welding brush on aluminum before and it's wild how much of a difference it made for the worse. If there's one thing I learned in welding school, it's that welding is pretty easy. It's prep and set-up that get you!
32,650
16,133
Reactions: GTPpower
