Mr_Roboto
25,913
31,092
The 86-87 throttle would have to be sealed since the MAF is pre-turbo. I have no idea what kind of pains would be in involved in making the IAC and TPS work with a stock 3800 computer though.
IAC and tps just need the right connectors spliced in typically. done it between my tbi, typhoon, lt1 and tpi throttle bodies.
Rdrnnr
wannabe racecar builder
Nov 15, 2020
1,361
2,386
Man I might be wrong and you'd think I'd know with my stock and ls1 sensor sittin 8 inches from each otherbut I'm almost positive that it and the 4.3 and 5.7 vortec mafs are the same connector even. The other two are just a hair underneath the ls1 in what they can read. And once you have stock sensor dialed in it shouldn't take much but a flash or two to match it back in but I'll have to let you know for sure.
Mine shouldn't be scaled now that I'm back on 91 for a short time and I'm gonna start tuning back in today to make some hits tomorrow so if I'm close to maxxin it again before I'm out of fuel pump I'm gonna wire it in and I'll keep ya updated on my thread on how it goes. Be cool to be able to open both our bottleneck throttle bodys a bit by gettin rid of that restriction and shove even more through these things
v6buicks
6,368
15,814
Franklin, IN
Jon
Any of you gn guys have a stock TB you want to sell? That accufab is a bit steep.
The stock GN stuff is small. Only 2.5" IIRC. I won't be selling my Accufab for anywhere near brand new pricing. If you want to borrow it to see if it works, I'll send it. If you want to keep it, it won't cost you a ton. Just PM me.
Reactions: Rdrnnr and GTPpower
GTPpower
6,350
9,752
Nebraska
So looking at GN throttle bodies more, I don't think it will work easily.
I'm wondering if these would work. Are there any dsm guys on here?
Reactions: Rdrnnr
