🔧 BUILD toyota wagon 3800
imma hack this bitch together in one month, and it'll take down dd's TR, HK's TR, pandawgs and 10sec's stock junk
:jg:
This started as a joke....and it still is....laughable at least....
But here is an index of what is going on with the 3800 insanity
Removal of 5mge/4spd auto.
32,648
16,124
Holy crap. I didn't realize that you were building a pre series this whole time. Neat!
get the fuck outta here with that pre series shit
its a 90 LN3 vinC from the toronado trofeo we originally hacked the front subframe out of and put into the back of the twin engine 442.
its replacement is on the shelf, a 95 SI L67 talldeck, this is technically a series 1.5 as it has the cam snout/Tchain design of the SII as well as something quite similar to SII die cast rockers.
the LN3 is ported and worked over quite well and is running a SII oil pickup and f body pan with a modified SII windage tray/pan gasket and the 86/87 fwd intake flipped 180
even though ill probably never get around to putting SII heads on the tall deck, at the least this engine will be getting the smaller and lighter SII crank and SII pistons with rebushed chrysler 440 rods to get the rod/stroke ratio fucktons closer to 2:1 than the horrible 1.5 ratio of the SII short deck
for now though this well worked over SI is far more than the pos toyota rearend can handle not to mention the 88 2.8L v6 F body 700r4
Reactions: SaturdaysGS
