🔧 BUILD toyota wagon 3800
imma hack this bitch together in one month, and it'll take down dd's TR, HK's TR, pandawgs and 10sec's stock junk
:jg:
This started as a joke....and it still is....laughable at least....
But here is an index of what is going on with the 3800 insanity
Removal of 5mge/4spd auto.
32,652
16,139
its all bolted down, basically set to run NA, all vac lines are hardline, L67 injectors, i ran a coolant loop through the ECT block (toy and GM sensors)
if i start it up ive gotta temp rig the fuel lines (ending up running all new feed soon) and rig a loop on the trans cooler lines
sealed the shit outta the lower, finished T stat neck shortening. tucked all the wiresunder the plenum, fuel lines are ran and ready for rigging, rear coolant and heater core is done but i had to cannibalize the clamps for the HC return hose for the ECT coolant loop.
gotta size a belt but i can run it for a minute or two without coolant so no belt isnt an issue
