Thinking of doing something with my tranny cooler
I
imported_GraFFix
Since winter is quickly approching, I want to disable my trans cooler..I have an idea and i just cant seem to find the parts..although I dont even know if they make them.
Im looking for some type of valve...the ideal thing would be a brass Y coupler with a valve that I can select which way the fluid flows. this way if i have it open one way it goes thru the cooler if i open it the other way it goes thru a bypass hose and never gets to the cooler. its a simple concept that would work great if I could only find the parts I need.
Also, does anyone know if the trans lines are pressurized and if they are how much pressure..I dont want to end up getting the wrong hose or wrong fitting and have them blow out.
Any help is greatly appreicated
mybluegtp
Burbank
I think Chrys and Steve (SNM) wanted to do some type of plate to cover it up, but I think they both have different coolers, Steve has DF and I dont know what Chrys has. :unsure:
I
imported_GraFFix
I dont want to cover it up I want to bypass it totally...I could just put a peice of sheet metal or even cardboard over the cooler, but i dont want to do it that way..
12secGTP
Des Plaines
I did come up with a bypass. I never was able to hook it up since i broke my trans cooler line on the way to IDD4 and never fixed it. I have all the parts at home.
I wanted to sell this as a kit at some point.
it consists of several couplers, a tee, a 3 way valve and a check valve. the check valve is the tricky part.... you need something that will handle the back pressure AND the temp of the trans fluid. they are quite pricey....
also, you really should have all brass fittings.
SnM
At home probably
yeah, chrys was working on this, i had an idea of covering the cooler with a sheet of aluminum, so the cooler won't work well, thus keeping temps up.
We have a lot of brass fittings at work, so I am sure I can find what I would need there. I still might try the cooler cover first just because it would be easier, and not as messy :p
I
imported_GraFFix
It would only be messy for installation after that it would be a painless way to stop using the trans coolers for the winter time.
Chrys if you could help me out here and tell me what your using that would help alot. or just PM me a parts list. :rolleyes:
I was going to stop at the industrial ace over here by work and just see if i could peice something together...
any help is appreciated
I
imported_Ron Vogel
Can you use a quick connect, like that you see on air compressor fittings? They are plugged when disconnected, and you could make a bypass hose. Talk to a welding supply like Terrace or something. Correct me if I'm wrong, but don't you work for a welding supplier?
