I used to have one of those!!!! Paired with a Texas Star 500.Whos got a swr meter to set my Wilson 500 up?
I don't know where I put mine. It's been years since I played with this stuff. I also need to find a nice microphone
I've got a dx66v as well. That talks at 80w or something, have to direct wire it from the battery with heavy gauge.I used to have one of those!!!! Paired with a Texas Star 500.
For a mic, go with Astatic. The D104 was the “go to” model, but I preferred the 636.
I need an SWR meter too. I found my old DOSY but it’s dead.
I can’t even remember where I had gotten all my gear. At one point I had two Galaxy radios, think the second was an 88DX. Also, somewhere I have a Cobra 148GTL. I have a President AR-144, and know exactly where that is.I've got a dx66v as well. That talks at 80w or something, have to direct wire it from the battery with heavy gauge.
I had chip at the truck stop do all my work. He was in Hampshire?? Near i90 and 47 I believe...
Found it, it was an Antenna Specialists Super Scanner. Man was I far off with the name. 6db Omni, 8.75db in beam.Oh, and that was just my mobile setup. For home I had a President Washington with a Tri-Star (?) switchable antenna. I have a 40A power supply that I drove a small 250w linear with.
The antenna had three sticks in a triangle, all 120° from each other, about 3’ from the mast. Using all three as a single point of propagation it only had like 6db of gain. But you could switch it so that two of the antennas would change to a ground plane and reflect your signal. So you could focus it in a 120° wide “beam” and get about 12db gain. That was a really great setup.
I’m trying to think of the base mic I have for it. That I kept since it sounded so good. I have it in a box, somewhere. I miss that President Washington. It had a channel kit to go +/- 40 channels with a frequency counter that had like 30Khz of adjustment. So I could be on channel 5 and “dial up” to 6 or 7 without touching the channel knob.
*Allegedly. I am not able to verify.
Not directly HAM radio, but I have an old Uniden Bearcat 8500XLT that runs most of the day, for local VHF/UHF. I just happened to spin the VFO to an open channel (unused), and started picking up WWV. WWV has been on only 2.5 MHz, 5 MHz, 10 MHz, 15 MHz, and 20 MHz. My scanner has a frequency range 25 MHz to 1.3 GHz.
Hmm.
Turns out WWV (NIST) is also doing an experimental broadcast on 25 MHz, which my scanner automatically defaults to on open and unused channels (000.0000 MHz). So, with a 30 year old Radio Shack "Archer" 3-element scanner antenna on my roof I'm picking up the signal out of Fort Collins, CO. I'm guessing atmospheric conditions are allowing that, cause it's not normal.
Radio Station WWV
Notice: Since November 15, 2021, WWV and WWVH has been broadcasting a test signal on minute 8 of eacwww.nist.gov
Yeah that's an "opening." I believe we are nearing the peak of the solar cycle expect it to happen more. Good time to be a CBer too.
Going to go with Skip.... not hearing anything (WWV) on 25.0000 MHz now.Correct. Propagation really good right now
More like a super cesspool. Sad to see how much garbage is on that band now. It's a competition to see who can be the most unintelligible. The last few times I ran through the channels I couldn't understand 95% of what was being transmitted. Main reason I started to get into GMRS and working on my ham ticket (again). Might aim for General instead of Tech.Did you hit the super bowl?
Agreed.... since I don't have any 6m equipment, not a huge concern. But for that 25 MHz WWV signal, it's open.https://www.idahoares.info/current_propagation.php
Looking at this you wouldn't even hit 6M honestly, however 10M should be well open.
