The beef with GDI and valve coking
89,546
i just read a few quick things about it after reading your posts.
Gum Residue
A compression test revealed low or no compression on some cylinders. Removing the valve covers and observing valve movement revealed some lazy moving valves or no valve movement on some cylinders. Pulling the cylinder heads and removing the valves revealed a gum-like residue, which was restricting valve movement. This contamination is especially a problem on low mileage engines with tight tolerances. A high mileage engine with excessive wear may not be affected. The condition is more pronounced once the engine cools down and the gum-like residue solidifies, forming a sticky, gummy-like substance. The problem with the fuel was determined to be a lack of anti-oxidants and deposit control additives necessary to prevent the formation of gum. This is common with fuel that has been in storage too long or blended improperly. Some of the engines required major mechanical repairs as they were interference engines.
Carbon Build-Up
Another issue that is becoming a common problem is carbon build-up. Detergents and deposit control additives are added to the fuel to help prevent the formation of carbon deposits on the intake valves. This condition is especially a problem with Gasoline Direct Injection (GDI). With this system, fuel is injected directly into the combustion chamber instead of on the face of the intake valves, which provides a fuel wash for any contaminates. Valve overlap further promotes the accumulation of deposits, as some combustion gases are forced past the intake valves promoting carbon build-up.
Carbon deposits promote misfires, rough idle, long crank times and no-start conditions. In some cases the engine will run rough for a few minutes and then perfectly until the next cold start. The reason is the carbon accumulates in a porous form and initially absorbs the fuel, creating a lean condition. Once the carbon becomes fully saturated with fuel, the engine will run perfectly. These deposits can collect on the fuel injectors, affecting their spray pattern, resulting in hard starts, misfires and excessive levels of hydrocarbons and carbon monoxide.
The carbon deposits can cause an increase in the compression ratio, often requiring a higher octane fuel to prevent spark knock. This can be a problem with turbocharged engines as the boost pressure increases the compression ratio to a level resulting in violent detonation. Higher compression ratios can results in pre-ignition of the air-fuel mixture, resulting in detonation. Carbon knock can also result due to the pistons making contact with the carbon deposits.
89,546
also somewhat related- i was also just reading GM has a patent on an integrated oil seperator assembly.
In Plain English
If all that engineering jargon is too much, here’s an explanation in simpler terms: the crankcase ventilation system will vent air out through a first oil separator, and – through the use of check-valves – it may continue to a second oil separator. The direction of the air is dictated by blow-by flow passages, and the separated oil is returned through drain passages.
The air vented from the crankcase can go to one or more openings, including an air intake system which can include a turbocharger. The second oil separator can include a pressure regulator valve that can regulate the system’s pressure via check-valves.
OffshoreDrilling
This is my safe space
HVAC Guy
Aug 28, 2007
39,237
50,929
Homer Glen
Messy but easy. Pull the intake off, $40 harbor freight sand blaster with walnut media also from harbor freight. BMW vac/blast nozzle that is contoured to the shape of the intake port.
blast the cylinders with the valves closed,vac out media, bump the starter to close the next set of valves and repeat.
3-4hr job
OffshoreDrilling
HVAC Guy
Aug 28, 2007
39,237
50,929
Homer Glen
I do miss your endeavors with that car, lots of good stories/content from it
I miss a lot of the projects I did with the cars I had. Dumb “unique” stuff.
TBSS AWD to 2wd conversion
DIY trans build 6l80 in the denali
Stupid BMW Turbos
NO PUKESTERS
95,746
HEY TAKE THIS SHIT TO ANOTHER THREAD YOU FUCKING ASSHOLES.
Reactions: b4black
b4black
before black
Jun 6, 2008
1,331
542
Oswego
BMWs and Mazdas had serious issues early on. The deposits were enormous and choked off air flow. Everyone either became super paranoid and/or used this as a way to bash DI technology. Same applies to LSPI (low speed pre ignition).
After I bought a 3.5 Ecoboost, I read about it being a must to get a catch can. But if you look at people that have had their intake manifold off for what ever reason, the valves don't look too bad. The MAP sensor hole is a perfect location to slide in a borescope and take a look at the valves. I'd do this before wasting hundreds on a catch can.
Don't fix problems you don't have. ;)
