Stock 04 GTP times from Byron.
F
fire87z
Well, I took the car to Byron Sunday, and man am I ever happy with the out come. The first run of the day was a [email protected], mind you this is the first time I have ever driven a front wheel drive car at the track. I had a 15.7 and a 15.1 after that. The 15.1 was going to be my last run of the night, but the car felt good on the run and I had to let up to get the tires to stop spining. So I made one more, [email protected] on a 2.1 60'. The car is a white 04 GTP with all the goodies minus the Comp G. Next year I hope to see 13's with only a few little items, seeing as it is the family car. :p
Glasuan
Wow, those are some nice times. Get a chip from Intense, from what I hear about 04's, its the best mod you can do.
VHGTP
[snapback]58902[/snapback]​
a chip?? what does a chip do for the 04's??
Fish
From the mean streets....
Chiraq
Actually, I hear the 04 PCM is more restrictive than the 97-03 PCM. So bigger gains Id say.
horist
Geek
Lake Zurich
[snapback]58973[/snapback]​
yup... the torque management is a bitch in it... i've never seen a stock previous model PCM (hmmm... though w/my new HPT update I can :D) but the Torque Management in my GTP was tons worse than the TA....
Only thing I don't like is that the 04s don't have a Performance switch option... (no feed into the PCM) ... I wanted to remove Torque Management when in performance mode (which I had incorrectly hoped was tap-shift mode) but leave it for normal driving... to save the transmission...
Not sure about timing and fueling though... haven't delved that far into it
