shift points for street and strip
Silverback
I took Silverback to an unknown tuner a while back and he did not really know how to tune the Marauder's transmission. I'm left with an unwieldy tranny tune.
So my questions are: In part throttle operation, at what speed should the 1-2 shift be made, and the 2-3 shift and the O/D? At what speed should the torque converter lock up, 45 or 65 MPH?
In WOT opperation, Is 6K RPM for at the 1-2 shift OK? What RPM for the 2-3 shift? What about O/D in WOT operation, left off?
The car has 4:10's and a 3500 stall converter.
Any dyno tuning shops that you can recommend within a days journey from Shreveport, La. would be helpful. I know about Mo's.
Thanks for your help.
Pat
i
musclemerc
Save your money with Mo's. His trans tune is lack luster at best. IMO Zack had the trans tune spot on
Trust me on this. I offered Jeff (Mo's main shop guy) a copy of Zack's trans shift schedule and he was too proud to use it
Silverback
Musclemerc;
Your comments are noted but I would like to know, frome your experience, information to my questions in post 1.
Regards,
musclemerc
To be honest Pat I would need a few days to reply. Here's why. I would need to load zacks tune then datalog the info so I can pass it along to you.
As far as dyno tuners go I would seriously consider JMS Chips in Lucedale, MS well within a days drive from LA
Silverback
No need to go through all that trouble. Thanks for the recommendation on a tuner. Worth a call or a visit at least.
BUCKWHEAT
Finally 11.927 at 117.25
Ladue, Missouri
Pat
i
Pat, Lidio did my trans tune & has the part-throttle shifts feeling 'normal' to Gina. My WOT 1-2 shift is at 6400 (with Crower cams). Same for 2-3. I always leave OD off at WOT. Power shifts are firm but not harsh, as with some prior tunes. Not a days drive, but could be a long weekend!
John
Zack
4 Doors 4 Life
NW Indiana
Pat, I will look for your file when I have time and see what's up. When I drove the car it seemed fine.
Silverback
Thanks, Zack. That should help in undertstanding what my SOP is telling me.
Regards,
Pat
BTW, Silverback's mom sends her best.
