See inside an internal combustion engine
Alacran
GM fanatic
Chicago
thats one of the best ones i have seen. Its been done before to analyze the combustion and determine how much times it takes fuel to burn once ignited.
If you look closely at the spark plug its obvious that the timing its advanced.
Poopshinanigans
I'm a middle of the titties voter.
can they use infrared cameras to determine hot spots and develop more even combustion?
