I use the $1.59 Autozone LOL hahahah but I change it every 4 passes lol
sometimes every pass, if you leave the oil filter gasket on.
No chance..
Have you ever seen Mobil's tests vs Amsoil? Equally as astounding..
RP is an API Licensed oil meaning it is used in Cummins and does not void warranties.
Amsoil is the oil that is NOT API licensed and would void a cummins warranty
what is the point of your post? nobody ever said it did void the warranty, and what point are you trying to prove without any facts? im getting confused here...i have posted pictures, lab tests, and facts.
it quoted that "Moly is a solid, specifically banned by Cummins, due to excessive valve train wear."
rp contains that property.
My point is that if it's banned by Cummins then if you use it your warranty would be voided right?
I think we all have options in life and one is to use whichever oil we want depending on what we have seen or heard. There is a reason why there are dozens of oil manufactures...
Mobil One has switched to dino base oils so they are not 100% synthetic anymore as of a couple years ago (to save money).
NOT TRUE. BIG CHANCE.
INDEPENDENT LAB TEST.
Royal Purple Info
As you may know, RP is big in racing circles. The chemistry they use is something we choose not to use. One of our big selling points is extended drain intervals. Some additive chemicals can cause adverse conditions when used for long periods.
Royal Purple uses a different chemistry than most. They are one of only a handful of marketers using Moly in their oil. Moly is a solid, specifically banned by Cummins, due to excessive valve train wear.
Moly (Molybdenum Disulfide) is a processed mineral that is similar in appearance to graphite. Moly has good lubricating properties when used either by itself (in dry power form or as an additive to oil or other lubricants). Particles of the Moly can come out of suspension and agglomerate. This can actually clog oil filters or oil lines and the rest normally settles in the bottom of the oil pan. This seems to be more likely when using extended drain intervals. The only test we ran on RP involved their 20W50 Racing oil versus our AMSOIL Series 2000 Synthetic 20W50 Racing Oil (TRO). We ran two 4 ball wear tests with different parameters, a spectrographic baseline, FTIR scan and volatility tests. The Royal Purple showed a significantly high volatility rate with a 12.51% boil off rate. This compares to TRO with a 4.47% volatility rating. Wear scars were also smaller with the TRO. For example the TRO left a .41mm scar and the RP oil left a .66mm scar. There was also a surprising difference in the viscosity index. The RP has a VI of 129 versus 155 for the TRO. The higher the VI, the better the viscosity stays in place at high temperatures.
This information was provided by AMSOIL Tech Department. They had an independent lab test Royal Purple against AMSOIL. The results are posted above. They have found Moly in Royal Purple. As stated above, this can have negative effects on your engine.
Well, just by looking at those pics I was convinced, I returned the RP and got Mobil 1 full synthetic, Thanks slash.
I use water, seems to work pretty good.
So you mean the sludge layer that eventually forms on the bottom of my kitchen sink near the drain plug is the same sludge that lines the bottom of the river?
Hell, I'm never buying tap/river water again!!
