well Al and I got some more shit done...didnt finish the heads but we did finish the pan modz n button up the bottom end.
advanced down the block had the Specter/SPI pan in stock 65$ out the door part number GMP11B
single layer steel
welded in the cyl 4 scraper and since our primary oil return is via the timing area i dented and folded the front nose for a more direct path below the windage tray and down into the pan.
one nice thing is this pan would make it easy to fab a large volume pan.
130$ and weld the bottom onto the other with a simple extension on the pickup tube...thinkin about it. definitely getting another one for the TR....if any car needs it the flaming turd does...
here you can see the drainback and the scraper with the jig installed.
the Timing oil drain path and chain scraper through the windage tray opening
you can see the longer tray slots actually open across both rods and most of the counterweights. sealed the shit outta it and screwed it down....
