I'm not sure about the F80. I haven't done any research on it as I'm trying to stay away so I don't buy a F80. Lmao
With the e9x you use an android device as the flasher. I have an old tablet I use. As well as my phone. So you need to buy a ODB II cable, conversion cable to plug that into your android device, MHD flasher license, and tune pack (back end tune). Once MHD is installed switching maps takes about a minute. Not bad at all. Not. On the fly like jb4, but not horrible at all.
For me, the cables were like $80, flasher license was $150, tune pack was $50, and data log licenses was $50.
The pic below shows what tunes are available with each pack. Each pack has different tunes for different octane fuel as well as blended e85.
You can do some reading. Quick search I found was this thread. Probably a good starting point.
http://f80.bimmerpost.com/forums/showthread.php?t=1450581
S55*(BMW M3 / M4 F8x):
Stage 1 (up to 530HP/700NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars.
Stage 2 (up to 560HP/780NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with high-flow downpipes.
Stage 2+(up to 585HP/850NM) - 93oct/98ron, 95oct/102ron, for cars equipped with a free flowing exhaust and high-flow downpipes*(in development).
Ethanol Mix Maps: Stage 1, 2 and 2+ E30-E50+ Maps for ethanol blends of 30%-50%+*(in development)
Topspeed limiter removed on all OTS maps.
As an alternative to built-in maps, many local and remote tuners can provide advanced custom mapping for those who have more extensive modifications or unique performance / customization needs.*
Monitoring and Logging Module:*
Monitor your engine behavior to make sure it is running perfectly using a configurable and very responsive gauge layout. 50+ engine parameters are available at a glance! Activate the logging mode to save the data to a standard CSV file for later analysis using the built in log viewer. Additionally, we will happily provide free logs analysis.
These are some of the available monitors:Boost,
Boost Target Lambda (AFR)
Intake Air Temp (IAT)
Ignition Timing per Cylinder
Coolant Temperature
Oil Temperature,
Oil Pressure
Transmission Temperature
High Pressure Fuel Pump (HPFP)Throttle Position
Wastegate Duty-Cycle (WGDC)
RPM
Speed
EGTA
nd many more…
MHD exclusive advanced monitor:
Timing Corrections per Cylinder
Base Compressor Axis: Boost Setpoint, MAF req WGDC.
Active Torque Limiters
And many more…
Flash-time Options::*
These flash options can be applied to any map directly through the app!(in development):
Exhaust Burble: Customize your desired exhaust burble (duration & aggressiveness) and enjoy the sporty soundN20 Map Sensor (on N55).Torque limit per gearMore options will follow with new updates.
Read DME Codes::*
Track issues by reading the error codes, and delete them once resolved.
New features and updates::*
The MHD Flasher F-series will continue to evolve after the release, which means many exciting new features and map updates will be coming in the future.*
The following projects are currently in development for 2018:
Flex Fuel Kit
MHD Wireless OBD-II adaptor
On the fly map switching
Exhaust flap control
Quicker flash times
Real time tuning
MHD anti-theft protection
Valet mode (reduced power and limited rpm)
What you need:*
Android device,*OTG compatible*with Android OS 3.2 and higher.
BimmerGeeks ProCable (K+DCan cable).
