I don't get why everyone's excited. This thing's going in F450+ trucks. It's not like it's going into anything that will let massive amounts of them out into the wild unless Ford makes a crate engine of it. You'll pay up the ass for one from a wrecked truck and that crate isn't gonna be cheap either. It'll be kind of like the Caddy V10s were in hot rodding days; semi exotic and something people gawk at when at the shows or maybe the track.
I can't see why anyone would not be excited about a new engine that has performance potential? Since the engine is already in a Foxbody, lead by a Ford employee that is a long time drag racer, I think Ford has plans for this engine beyond the RV crowd.
Because old man. Coyotes are the future and nothing else can ever be done to dethrone the Coyote, even Ford themselves.
Just like the retards on FordRaptorForum. "Blahblah the 3.5 ecoboost is a far superior engine than that shit 6.2 and Ford isn't investing any more money into V8 platforms. But if the Ecoshit ever blows, I'll just LS swap my Raptor because the Egogarbage is too much of a headache. But it's clearly the superior motor." That's a serious comment someone had the other day.
I'm not sure why anyone would choose this setup over the tried and true Coyote outside of trying something unique or new (with Ford's latest engine). The aftermarket is huge for the Coyote, has a plethora of tuning support, and you can make big horsepower very easily with boost. I'm just not seeing the allure here.
Compactness would be a big one. This will fit early Mustangs as mentioned whereas a Coyote would be a real headache.
You have to remember something, a lot of engine swaps are used in racing. The coyote has a couple of big disadvantages. One being you can't repair most things on them between rounds. Push a head gasket and turn it around in 45 minutes? No way. Not with even a simplified locked out cam set up.
The 7.3L has a lot of old school engine building tricks already applied to it from the factory. Canted valve heads, swirl combustion chambers, 320 cfm intake flow stock (thats a big number), dry intake manifold (not uncommon anymore), and so on. This motor is easy to tear down and reassemble as any old school SBF. Maybe easier with the intake being flat, o-rings instead of gaskets, and no sealant needed at the water crossover/ports, or sealant at the front and back of the intake. Plus a stout block and rotating assembly that negates buying an expensive aftermarket block or crank. The Ford engineers got to hot rod a stock motor under the guise of reliability. I think the aftermarket for this motor will come along WAY quicker than it did for the coyote too.
This might not be the best swap for everyone with a street car. But I have a feeling it will be very popular for big hp builds as well as drag racing applications.
If you want to keep the chassis 100% stock, but most guys I see doing nice swaps are cutting up the shock towers and putting in an IFS setup or the bigger money builds are swapping chassis (IE Schwartz or Roadster Shop).
I assume this is all old news?
Ford's 7.3-Liter V-8 Makes 789 Naturally-Aspirated Horsepower With Built Internals
The giant gasoline V-8 in Ford's new Super Duty pickups can make huge naturally-aspirated power—and it can fit in a Fox-body Mustang.www.roadandtrack.com
