Pop noise when going over uneven road
27,986
Try a search for the rear end pop/tink on SVTPerformance. Sounds like you may have it. Chicago Mike and I discussed this issue years ago on SVTP before ChicagoSVT was born.
If not that, it could be the body panel rubbing problem or some other rear suspension problem but it sounds like pop/tink from the way you are describing the noise.
Unoid
Libertarian Massa
Aug 30, 2004
2,494
thanks cliff
ChicagoMike
2,229
Actually if it's not the tink... because the tink is caused by the axle spines missing, and it can be recreated in 1st and reverse...
Check the catback, sometimes the pipes are mounted too high and bounce off the fuel tank cover or elsewhere, inspect for marks of this happening. otherwise if it's not this or the tink, have the rear suspension inspected. Check wheel bearings, suspension parts.
27,986
Steve, try driving backwards and forwards in reverse and first for ten or twenty feet and see if you can get it to pop. If so, it's a good indication it's the pop/tink. If you don't get it to pop by reversing direction, look towards other parts like Mike mentions.
