Passenger Window Problem
fastss
street militia
NW Burbs
My passenger window on my 1997 Camry does not go down anymore. I have the door panel off and i used to be able to push it down with the drivers side switch while supporting the actual window down. It would go up with the passenger side switch.
Now it does not go down at all. The window motor makes a click sound when i push the switch up while it's all the way up.
The window did go down the other day, I put a LEXUS switch in from an ES300 and the wires heated up but it did not work. Put the old stock switch back in right away and it went down and up. Couple minutes later it did not work.
A bolt was always loose and raddled when it would go down for a while. Then the day i knew it was time to fix it was when it went down off track. Then it stopped going down completely.
So lost and wanna repair myself but i do not think that will happen if i cannot pinpoint the problem.
Theautoguy
Machesney Park, IL
Check to see if there is a wedding ring lodged somewhere in the mechanism. My wife stopped going down after that happened.
SRT41320
Lake in the Hills - IL
lol - prolly the moto/regulator goin bad - or being a toyota....if the drivers switch goes bad none of the other switches wil work....start by getting the window back on track - then disconnect the motor plug and hook 12v from the battery to it - one way will make it go up and flip the wires and it will go down....if it works fine then its prolly the drivers switch (being a toyota and their dumb logic) if it dont go up or down...then buy a motor/regulator setup....G/L
fastss
fastss
street militia
NW Burbs
So run 2 wires into the little socket? and when it goes down flip the positive and negative and it will go back up?
can i use an ohm meter to check this also? see if i'm getting voltage from the motor socket and then check the switch socket?
SRT41320
power window circuits are gay - difficult to check motors with ohm meters sometimes....and relays can turn off before the voltmeter registers power.....
just take a power and ground wire to the motor plug...one way is up and flip the wires and it will go the oposite way....thats how to test the power window motor.... easiest to check so i would start there...
fastss
fastss
street militia
NW Burbs
Alright i will try that. Thanks a lot.
I'll let this thread know what happens
fastss
fastss
street militia
NW Burbs
alrighty - let us know
Bad solder connection on the master switch !
You were correct if one switch goes out then both do. Window is back and no more problems or rattling. Thanks for the logic sense.
