My passenger window on my 1997 Camry does not go down anymore. I have the door panel off and i used to be able to push it down with the drivers side switch while supporting the actual window down. It would go up with the passenger side switch.
Now it does not go down at all. The window motor makes a click sound when i push the switch up while it's all the way up.
The window did go down the other day, I put a LEXUS switch in from an ES300 and the wires heated up but it did not work. Put the old stock switch back in right away and it went down and up. Couple minutes later it did not work.
A bolt was always loose and raddled when it would go down for a while. Then the day i knew it was time to fix it was when it went down off track. Then it stopped going down completely.
So lost and wanna repair myself but i do not think that will happen if i cannot pinpoint the problem.
