Newbie here. advice with a build
Gunner
I have a 2003 Marauder and am looking at options to put in an aluminator with a 2200 s/c or the YSI s/c. First off I'm not that mechanic savy and am a little confused with compression ratios and why it would matter with the blower. Just need your input about the blower and which comp motor to go with. What is the stock comp ratio anyways?
myrodr
stock comp is 10:1 how much boost psi you looking to run?
Dohc324ci
Think budget and goals in mind. Modular power isn't cheap. Eaton conversions are the most cost effective if not in Cali.
SC Cheesehead
God Speed Blues Brother
^^^^^^ What he said. ^^^^^^
For $4K or less, you can get a set-up that'll easily give you 420 - 450 rwhp.
Gunner
Ended up going with a MMR900 and a vortech JT trim blower. This should make some power for me. Pics with a build thread will follow in the weeks to come.
Gunner
Well. Also have the kooks headers, port polish intake borlas Turbo XL mufflers and on and on. Will post the rest in time. Making me depressed just listing everything while its still in pieces awaiting atransplant transplant. Haven't drove it in 8 months. .
Dohc324ci
no worries man...it took 2 years for me to get to where mine is now;) I know the feeling.
4DoorBlackTop
2003 or 04 Cobra short block, have your heads machined and it'll take anything that's still streetable.
