Move Over Tesla: Rivian R1T Electric Pickup
Bub
Pitter Patter
Posts
13,745
Spring Grove
https://jalopnik.com/rivian-r1t-the-electric-pickup-with-a-front-trunk-that-1830646607
help
The best details, believe me
Like a lot of electric car startups, Rivian has been something of a mystery. With just 560 employees, the Plymouth, Michigan-based company bought a former Mitsubishi factory in Normal, Illinois last year but has kept itself largely under wraps—until now. After years of working in the shadows, Rivian is debuting its all-electric pickup truck, the R1T, as well as itself as a company, today on the world stage. And if Rivian can pull this off, it could do for trucks what Tesla did for luxury sedans.
(Full Disclosure: Rivian bought us lunch and showed off the R1T to us in Detroit a little while back.)
So you may be thinking: What the hell is Rivian? While it isn’t coming out of nowhere, it hasn’t exactly tooted its horn much until now, when it plans to show off its wares at this week’s Los Angeles Auto Show.
But instead of building hype, Rivian says it’s been building a business, utilizing the expertise of Michigan locals with automotive know-how. And there’s the Mitsubishi factory in Normal, Illinois, with plans to invest over $175 million into the site by 2024, InsideEVs reports.
So it’s refreshing, in an age where most startups feel like they run on hot air, to see some rigorous planning instead of just empty promises.
My first thought at seeing the fascia of the R1T was that it reminded me of way back when Google was building its own car, only all grown up. Like a nerdy friend you’ve had since middle school who came into their own as an adult, the same round-eyed nerdishness has now morphed into something surprisingly attractive.
The light bars across the front and back also recall the Volkswagen Tanoak concept. The light bar even flashes green when it is charging, like an electric toothbrush. The future is indeed here, and apparently, it involves a lot of light bars. (They’re still cool, just don’t overdo it, automakers.)
Admittedly, it looks very concept-ish for now. But behind one of those light bars is a Jalopnik holy grail: a frunk. A glorious frunk that can fit a huge cooler and duffel bag with ease. Rivian’s skateboard-based design (think of it as a battery on wheels) allows for some entertaining use of space and the company takes full advantage of this.
There are enough hidey-holes to satisfy even the most accessorized outdoorsy person, including a tunnel storage unit ahead of the back wheels big enough for your snowboard. Plus, the hatch door of that doubles as a seat.
The large bed is wide enough to store a sheet of plywood, comes with a cover as well as customizable cross bars and roof rails that owners can move or switch at any time. The bed includes an air pump for bikes as well as an integrated security cable to keep unattended items safe in the bed.
Each wheel is powered with a 147kW drive unit, allowing for precise torque control. It also means all of the power and batteries sit below the height of the wheel. This naturally makes for a low center of gravity for Rivian to build up on, perfect for a truck or SUV.
All of that torque and power push the R1T from 0 to 60 mph in a claimed three seconds and 100 mph in less than seven seconds. Also, they say it can tow up to 11,000 pounds.
Between those wheels can sit several different sizes of battery pack, the largest being a 180 kW battery pack that can reach 400 miles on a single charge and will hit 80 percent battery power in under an hour using DC fast charge. The really interesting claim is this: Charging for 20 minutes lends 100 to 150 miles of range, more than what most people drive in a day.
That’s very much on the optimistic end of what we have now with EVs, but it feels attainable.
Inside, the truck is roomy and as ready to party as the exterior. The floors are made of tough rubber rather than carpet, and the seats are covered in a tough but soft woven vinyl fabric called Chilewich. The entire interior was built for wiping mud off of while keeping in touch with the modern world.
No less than 10 USB charging ports are splayed all over the interior, which also means Instagram will never miss out on your woodsy exploits.
The point of this truck is to be both a daily driver and outdoor adventuring vehicle. The R1T comes with off-roading maps pre-programed into its navigation for a reason. Designers and marketers at Rivian point to brands like Patagonia as inspiration for their designs and consumer set. Cliché? Maybe, but also not a bad idea if that’s the audience you want to aim for.
Rivian says it wants to prove that an electric car can be tough and rugged as well as environmentally friendly. The truck is designed to be an off-roader, with the giant skid plate undergoing testing similar to ballistic events to make sure the precious battery pack can’t be punctured on rocky roads. And it’s so well sealed up the R1T can wade into a almost a meter of water, despite its low slung battery pack.
To keep that battery pumping out the juice, an advanced cooling system is used to keep the cells at the perfect performance temperature, regardless of terrain or outside heat. Adaptive control algorithms learn driver behavior, optimizing user-specific battery management for maximizing battery life, reliability and second-life reusability. Rivian also claims the R1T will come with semi-autonomous tech and all the safety features you’d expect.
Rivian says the truck starts at $61,500 after the $7,500 EV tax credit, and that it aims to start deliveries in late 2020. The fully equipped, 180 kWh and 135 kWh battery trucks will begin production first, with other variants to follow, the company says. A base variant with 250 miles of range will come later.
The company is aiming for a direct sales model, which may get them into hot water in their own home state, where Tesla continues to challenge Michigan’s ban on the no-dealer-necessary model. (Remember Tesla also says it has a pickup truck on the horizon, and given the dominance of trucks and SUVs in sales at the moment, someone’s going to pull this off sooner rather than later.)
Other electric car startups have made lofty claims before, but Rivian wants to prove it’s the real deal. That may a tougher job for this truck than any towing or hauling.
Bub
Bub
Pitter Patter
Posts
13,745
Spring Grove
I want to see the charge range when towing 11,000 lbs. This could be interesting
lastls1
Posts
11,717
It is honestly interesting and created quite a buzz on some of the Tesla networks I am apart of. No one has a truck yet so a lot of people are taking notice.
The first thing that caught my eye was the huge Frunk. Pickups are obv all about towing and storage... so that is a major plus for anyone looking to actually use their truck to do truck things. Put your luggage in the front and your outside gear in the back without ruining interior room for passengers. Huge Plus.
The price is actually pretty comparable to the market. I feel this will take off faster than any competitor car. Trucks are stupid expensive these days and hold value especially your loaded models or diesel versions.
I look forward to seeing the non concept version and how it looks.
Harbor Master
Posts
105,379
dude, you're kidding right?
lastls1
Posts
11,717
There is currently no other electric pickup out there. Pickups are expensive.... why wouldn't it take off? When you compare similar features in said trucks the price really starts to climb.
Also they claim this truck can tow 11k pounds. A 53k new ram 2500 power wagon cannot tow 11k pounds. and that is without customizing anything on the truck.
Harbor Master
Posts
105,379
dude. a $35k new f150 will pull 11k pounds... wtf are you getting at?
you can get really nicely equipped gm/ford/ram trucks for low 40s all day long with all the features truck buyers want to pay for.
just because this could be the first electric pickup truck doesn't mean it will take off- just like the first electric cars didn't take off...
Harbor Master
Posts
105,379
thing's a prototype and their "plan" is to put 175 million into the bloomington normal factory by 2024... :rofl:
sounds like i and every other truck owner on tcg will be trading in our pickups next week after this thing "REALLLYLYY TAKES OFFF"
lastls1
Posts
11,717
Lol jesus. I compliment Teslas and you fight me.... I compliment something that is not Tesla and is a direct competitor.... and you fight me.....
I am not sure if you just want to argue about Electric stuff just for the sake of arguing or if you really just hate this new tech that much.
Harbor Master
Posts
105,379
I'm not fighing you, I'm pointing out hilarious holes in every post you make.
It's amazing
Harbor Master
Posts
105,379
i didn't realize tesla had a pickup truck coming out next week to be a direct competitor to this prototype truck which is going to sell like hot cakes after the factory becomes a thing 6 years from now
:BOWFUCKINGROFL:
lastls1
Posts
11,717
:BOWFUCKINGROFL:
what in the hell are you talking about lol. No where did I post Tesla was coming out with a truck soon. I was complimenting this truck you Dolt.
You are trying so hard to poke holes in everything you are ending up making yourself look dumb.
Stink Star
Don’t Drive Angry!
Posts
13,910
Big wood cock
It’s a big challenge. Typical truck buyers are the last people on earth that will accept electric power as being not only as good but even better than gassers. 99% of the people I know/work with that are into trucks comment all the time about how Tesla sucks and an electric truck wouldn’t work because they “don’t have enough power”. Seriously if everybody drove an electric vehicle for a week, they would completely change their tune but bro-dozer people are the last kind of people that would give electric a chance
Harbor Master
Posts
105,379
you
are
a
fucking
moron.
"is a direct competitor"
to be a direct competitor, wouldn't the vehicle have to fucking compete in the same goddamn class you ignorant fuck?! aka also be a truck?
jesus
Harbor Master
Posts
105,379
this.
Stink Star
Don’t Drive Angry!
Posts
13,910
Big wood cock
jesus
To be fair, Tesla has teased an electric pickup truck so they with be a “direct competitor” before any of the big 3
Harbor Master
Posts
105,379
so this electric car startup that has to raise 175 million to build their factory will just be good to go with a legit competitor then? :rofl: come on guys.
lastls1
Posts
11,717
you
are
a
fucking
moron.
jesus
Its an electric vehicle you dumb fucking ape. Tesla has stated they want to come out with a pickup.... no they have not released details... but an all electric start up company would be a direct competitor? If someone was looking for an all electric vehicle choices are slim right now.... so yes I would consider this company in general Tesla competition.
Do you think they would just stop at a pickup truck and be done? If Tesla just stopped at the gen 1 roadster they wouldn't be a company right now!
