Modifying Tools
DynaSlim
Plainfield
Just had to modify this hoist i borrowed that ended up being too short. Those spohn sub frame connectors are strong.
Anyone else got any neat things they've done to get the job done on time?
IZZy
Powered by ES
I dont know if Id call that neat
Donnie
Ethanol Junkie.
Tempe, AZ/SOUTHSIDE, IL.
I modified my Framing Nailer once. This is tricky, but you should try it, Slim. So worth it!
Here's how it works, press the barrel of the nailer directly to your temple until the safety disengages. Now, that done, pull the trigger. This will activate a magical kitty-rainbow-candy party!
Go try.
Thirdgen89GTA
Buffalo Grove
1quick
coal city
Hay slim I bet square stock isn't that expensive maybe you could have picked up a piece a foot longer than what it came with and I don't know drilled a couple holes in it and lifted the motor in a somewhat safe fashion
Thirdgen89GTA
Buffalo Grove
I need to do that. I always forget the boom is about 4" too short for a thirdgen's nose.
Half of the effort needed to pull the engine is spent on keeping the hydraulic ram from pressing into the nose of the car you lift the engine. But if the boom was just 4" longer I could avoid that risk.
The thirdgen nose is pretty damned long.
P40E
There's a reason why the boom isn't supposed to extend out that far . :ugh:
1quick
coal city
We could only hope slim decides to work under it while its extended out too far and it tips over on him
Mr_Roboto
Joliet
On a gravel fucking driveway like a bauce
Shit's anti gold chainer.
This is begging to end with a front clip that's broken. I do have a stupid question for both you guys, you ever try to go over the fender? Hood clearance shouldn't be an issue since they both have em off.
Shit's sorta scary man. I do have a question, engine blow up? If so what'd you do to it?
Mr_Roboto
Joliet
You done getting the pieces of this thing back together yet?
Thirdgen89GTA
Buffalo Grove
It's difficult to over the fender if you are pulling the trans with it.
I've always managed just fine from the front. Just gotta be careful about it.
