My goal is to go fast. If possible, I would like to be able to crack into the 11's. Not sure if that is doable without heads.
And speaking of heads, would it make sense to run a bigger cam on the stock heads?
To crack 11s in that heavy gto you will need more than just a basic cam install. Your going to need rear suspension, shocks and drag bags. A sticky tire.... Preferably drag wheels and tires......... Have you ever picked up a stock gto wheel and tire? It's a god damn piece of lead.
So I guess your recipe then is a large cam. Forget those 224 or 228s you mentioned. A high stall. Preferably 4000, rear suspension, sticky tire or drag wheel setup. Minor weight reduction. (Lose front sway bar, spare tire, maybe rear seats? For track only.
