They only go to 6get as new as a tahoe as possible with as many trans gears as you can afford.
They only go to 6
They only go to 6
Don't some of the newer ones have 8?
well this was a weird hole to go down.
https://tbssowners.com/forums/6l80e-6l90e/59446-6l80-90e-swap-faqs.html
Yea, but a lot of coin, especially if you have an AWD SS.
How much is a built 4L60? Plus 6 speed!
The place I have my transmissions done at, FLT over in Wooddale (Chuck);
A maximum performance (level 7 I believe) 4L65E, is around $4,200. This is $6,800 for the AWD version, and requires a lot of electronic modification, as well as driveshaft modifications if you go with the 6L90 because it is about 2" longer than the 6L80E, all to get 2 extra gears. I'm not knocking it, as if I had TCG stacks, I'd want to have the most amount of gears available. But I think that there is more cost effective, easier to swap options, albeit with 4 gears, out there.
As to why they blow, 4L65E's aren't known to be considerably strong transmissions when adding bigger power to them. Add in an heavy (4,300 pound) SUV, with AWD, and something's gotta give on hard launches. Usually, it's the front driveline, but...
