đź’ˇ Fun fact. Whenever you start a thread, TCG Mechanic 5000 (our AI bot) will reply to you to start helping. It doesn't know everything and it will struggle with more complex questions but it can get the thread going and provide valuable information. You can choose to disable it prior to submitting a thread.
I've read multiple stories of people throwing on a larger lower pulley and then mashing on it without a tune and venting the block. Does the L motor not use knock sensors to pull timing?
Lightnings have knock sensors however they are not used. Ford could not get the knock sensors to work with a roots style supercharger. The supercharger makes noises/vibrations that throw off them off. This is the reason you hear of so many lightning engines failing that along with the weak rotating assembly.
