Knock after 3.25 pulley install....
markymarc
I had the ZZP pulley system installed with a 3.25 pulley. After a scan while driving, I am getting 4-6 degrees of knock at 80% throttle. Obviously I need to do something. My current mods are:
3.25 pulley
Thrasher CAI
Intense 1.9's
Ceramic TOG's
DHP
MSD Wires
180 Thermo
Ubend
I am guessing that colder plugs are a must, but what else can I do to reduce knock? Should I see Charles to have my fuel mapping increased? The scan showed that I was running lean at certain points.
The car hauls ass like you wouldn't believe, but I am taking it easy until this issue is resolved. What level of knock is safe or acceptable, given these mods?
Any help is appreciated.
superchargedgp
3.25 pulley
Thrasher CAI
Intense 1.9's
Ceramic TOG's
DHP
MSD Wires
180 Thermo
Ubend
[snapback]57700[/snapback]​
do you get knock at WOT?
S
sr71_rgl
I'm suprised you're getting any KR at all w/your mods. Like Mike said, are you getting KR at WOT? Colder plugs like a-lite 104s would probably cure all your KR. 4* of KR at WOT isn't going to hurt the motor in this weather but come summer time and 80*+ temps that KR will double. Try the plugs and post your results.
Glasuan
Plugs are a must of course, and based on mods you need 3 steps colder. The only other thing I can think of is DP, and hi-flow cat. Otherwise if you are running lean, check the fuel filter, replace it if it has not been for a while (over 50k).
markymarc
Thanks for the feedback. I don't have any readings from when I was running the 3.4, and the knock now is from 85% throttle, so almost WOT.
I'll try the plugs first and have it rescanned.
00 GTP Debadged
I have basically the same setup and run 104's in mine. The 103's are too cold in my opinion. I see better mpg and performance with the 104's. I would definately get a hold of Charles. I see absolutely no kr with the 3.25 even on 90 degree days.
Randy
markymarc
I am going to have 104's dropped in, to see if that helps. Yesterday I drove downtown to work on I90 in the cold air and loved it. The car pulls like a mo fo now. I thought this would be it for mods, but who am I kidding? Is the new ILGPC IC going to be released next year? I am thinking that is next for me.
