K & N myth
BigJermGTP
Montgomery
My bro saw this on the K&N site. I've heard about this myth on this site a few times also, never really belived it. That's probably because I don't take my car to dealerships, and I've never had a new car to worry about it. What do you guys think?
K & N MYTH BUSTED
Jeremy
PANDA
FRG
Interesting...
I had to replace a MAF before because the machanic said it got ruined with K&N oil...
PANDA
FRG
You should send him the link and ask for your money back.
[/b]
It was actually my dads friend, he didn't charge me. But replacing the maf did fix my problem.
phat_ridegt
Ottawa
they're lying.
i have experienced first hand. several times, which the oil from a k&n style filter was causing false maf readings, and driveability.
what they are saying, is a properly oiled filter wont cause the problem, which is probably correct, but when they are over-oiled is when the big problem arise. im not just saying it cause i word for a dealership, im just sayin, that everyone has a gimick, and i think this is their way of re-assuring customers
PANDA
FRG
they're lying.
[/b]
My MAF problem happed a few days after I "recharged" my filter.
BigJermGTP
Montgomery
Hey Mike,
The reason I got the CRC MAF cleaner from the parts store was because someone on here, I'm thinking it was you, told us about it.
I usually clean it a few thousand miles after I re-oil the filter. My MAF isn't bad, but how would I know, I'm a dumbass that doesn't scan.
I'm sure most people don't do that, and some, if not most people over oil the things.
PANDA
FRG
Hey Mike,
[/b]
Yeah, I think I posted that along time ago. It said like "adds 5HP" on the can or something.
Mike K
Forum Sponsor
I liken this to Cigarette companies doing independant research that proves cigarettes aren't bad for your health... :)
1BADGTP
Homer Glen
It's just like anything tell them to prove your such and such mod made that part break. Its really easy if you yell in front of customers!
J.E.T.
I've used KnN on all my cars with no problems. Just follow the cleaning directions and dont over oil it.
KnN seem to stand behind there product:
Pledge Details
K&N warrants that a properly installed and maintained K&N product will not cause harm to any engine component and will not result in a warranty denial. We will promptly reimburse the consumer for the cost of the repair if a dealership denies warranty coverage as a result of a K&N product. In order to receive reimbursement, a consumer must provide the following:
1.A written statement or repair order from the dealership in which the dealership blames the problem or warranty denial on a K&N product.
2.A written request to the dealership to send the broken part directly to K&N at K&N’s expense. We will need the evidence.
3.Your cooperation in helping us pursue our claim for reimbursement from the dealership.
K&N will then contact the dealership and insist they present evidence to support their allegation or reimburse K&N for the cost of the repair. We strive to exceed consumer expectations. Customer service can be reached at 1-800-858-3333.
I
imported_GraFFix
I didnt click the link, but Ill add my 0.2 cents in...
I think K & N filters can and do screw up MAF's, But K&N isnt at fault for this. When you first buy a K&N it is oiled correctly, its when people "recharge" and clean them and re-oil it themselves is where the trouble starts. Ive seen it many times.
Actually I was having a surging idle issue on my mustang and one day decided to pull the MAF and filter off to just check them. The filter was a little dirty so I was just going to blow all the crap off of it with the compressor. I stuck my hand inside the filter and started blowing I pulled my hand out and it was covered in oil. The previous owner over oiled the filter. After 20 minutes of high pressure air going through the filter I finally got it to where there wasnt any excess oil. Bought some MAF cleaner and my idle was like night and day.
I would say any MAF problems with a K&N filter is user error rather then the MFG.
alexgtp
I have used K%N filters in all of the cars I have owned. ALways properly charged. I have never had a problem.
I
imported_Theautoguy
I have used oily rags instead of a basic filter and have never had a problem!
...What!? I have a lot of oily rags.
chipmonk212121
another thing is that people will recharge their filter...... but put it back on too early
Sinister Drag Designs
SinisterDragDesigns.com
Chicago, IL
exactly chip, they need to dry in the sun for at least a couple hours. ive done this every time and never had an issue. Having a turbo is a little nicer, there is little chance oil will make it all the way to the MAF
Toasty
Bolingbrook, IL
[/b]
you blew out the filter with high pressure from a compressor??? ACK
yer not supposed to do that! :banghead:
I
imported_GraFFix
Well, Ive been doing that to my K&N's for 10 years and havent had an issue yet. Theres a ton of crap that builds up in the folds thats not going to be coming out with a normal cleaning/recharge. Regardless if your supposed to or not I dont see why it would make a difference. After all it is a air filter, so what if its coming at 90psi :)
Anyways it helped my idle issue by removing all the excess oil the previous owner put on the filter. Setting it in the sun wasnt going to help all that oil dry up at all...
Toasty
Bolingbrook, IL
[/b]
eh, in most cases blowing high pressue air like that through the filter will enlarge the air passages/holes in the filter media, thus allowing more dirt particles to get through the filter... oil may help catch them though
phat_ridegt
Ottawa
<div class='quotemain'>
Yes, improper re oiling.....thats the cause.
[/b]
If you watch the one video, they completly soak a MAF sensor in oil and no effect to the sensor at all.
Soak in oil
[/b][/quote]
right but the problem lies when oil it gradually added to the probes of the sensor, it cant distinguish whether its getting more air or not, and therefore cannot correctly adjust the engine fueling, making it possibly run bad, and/or cause an SES light.
tdc30
i had an audi tt and others said this had happen on there tts but they said if you take that air spray to clean your keyboard and spray the maf it should clean it
