[MENTION=1983]Outlaw[/MENTION]
https://chicago.craigslist.org/nwi/cto/d/2003-ford-f650-with-stahl/6443248624.html
Bought it a few years ago and have been working on it ever since with multiple upgrades. It has a new motor built by 505 Performance. As you can see I didn't go cheap on this build. The truck was purpose built to off road but I loved driving it that it became my daily driver. Ready to go off road or just drive around anywhere. Not much that this truck will get stuck in and if you do, the winch will get you out.
4.9L Stroker motor
camshaft stg3 217/223 272/280 .484 .494 lift ground on 114 hydraulic
compression 9.2.1 25 cc dish race tec forged piston clearance .004 to .005
rod custom 6 inch billet scat
crank scat custom 4.00 stroke
stage 3 cylinder head full port stainless valves 2.00 1.570 dual springs
roller rockers 505 performance
70 mil throttle body
custom intake manifold
motor 325 hp 400 torque
oil pump standard
oem harmonic
deck clearance .015
brg clearance mains .0021
brg clearance rods .0018 to .0022
Bore size 3.9405
cu 294 cu
spark plugs 2924
Tuned by 505 Performance, SCT flash tuner included with sale.
Have stock tune, and update can always upload new tune as needed.
Airaid Cold Air intake.
FF Dynamics
Triple Threat E-fans
Exhaust:
Banks Power Header
Random Technologies Cat
Full exhaust redone by local shop front to back with dynomax muffler
Lift Kit
8.5 inch BDS Long Arm
Installed by Attitude Performance
Gearing
4:56 Gear ratio front/rear
Yukon Gears with Eaton true track lockers
Tires
BF Goodrich Mud-Terrain KM/2
35x12.5x15
Lighting:
Full Strobe kit front headlights and rear tail lights
Atomic LED clearance lights with strobes.
Installed by Koda Electronics Franklin Park
JW Speaker Model 8900 LED headlight
Rigid Industries
D-Series Lights
$10,000! someone should tell them to post it on the expo portal place you keep talking about.
