so i can keep it running if i attempt to hover RPMs around 3000... it still lurches, but i can keep it alive. but it REAKS of fuel while doing this.
no changes with unplugging maf, iac, iat, tps, map.
plug wires are on correctly
no blown fuses
no damage to wiring harness
backside of fuse panel looks untouched
ICM and ICM harness look untouched
havent checked the vacuum line yet, or cam/crank.
but it still starts quick, highly doubt cam/crank problem.
If the vacuum tee is really busted, you will have a manifold leak, a bad MAP sensor reading, and high fuel pressure . I'd check it next, just saying.
