James, call me when your awake
daturbosix
HNIC @ GoodFellas Garage
16,367
15,194
Jeff
Asshole, who sleeps this late
symptoms are as follows...
-charger belt/pensioner broke and sent the belt flying
-another shop repaired that
-now it will start then immediately die like your turning the key to off, 5 seconds later
-no current or previous codes
-limited data(so says the previous shop)
-no change when unplugging maf, iac, iat, map, tps
-we have fuel pressure with KOEO, once started, when it dies, fuel pressure drops off... is something telling the pump to turn off???
PANDA
Event Coordinator
8,519
Wisconsin Northwoods
02BlueGT
No Fucks Have Been Given
Feb 21, 2008
9,922
18
Now apearing in Hanover Park
Things to check/ places to look with those symptoms in mind:
Vacuum Tee under blower snout
Ground on strut tower under fuse box
Fuse box itself, fuses may be ok, but the wires under/inside may have been hit :dunno:
Wire Harness, it runs both behind the motor (level with PS pump IIRC) and over the radiator in line with the belt.
ICM and ICM harness as it runs in belt area
Crank Pos Sensor and Cam Pos Sensor, also in belt area.
Hope that helps.
[MENTION=945]daturbosix[/MENTION]
daturbosix
16,367
15,194
Jeff
so i can keep it running if i attempt to hover RPMs around 3000... it still lurches, but i can keep it alive. but it REAKS of fuel while doing this.
no changes with unplugging maf, iac, iat, tps, map.
plug wires are on correctly
no blown fuses
no damage to wiring harness
backside of fuse panel looks untouched
ICM and ICM harness look untouched
havent checked the vacuum line yet, or cam/crank.
but it still starts quick, highly doubt cam/crank problem.
Mike K
13,214
2,586
I don't see where the symptoms were listed but with the limited info I do see my first instinct would be to pull fuse 21 under hood and verify that's good, especially if unplugging the MAF isn't having any affect.
It's been a while but if I remember correctly the MAF shares a common ground with a lot of the other sensors there.
daturbosix
16,367
15,194
Jeff
It starts normally, then 5 seconds later cuts out as if u clicked the key off, but if I tickle the throttle to about 3000rpm it will stay running(but surge) until I stop, then die like turning the key off, and when I do that there is a STRONG fuel smell
deviantlx
1,814
10
fuel pressure regulator? check the oil level and see how high up the stick it is from washing the cylinders with fuel. thats a good indicator it went bad.
1quick
26,554
24,010
coal city
just for shits ground the bolt on the trans that has a few ground wires on it to the body of the car a nice clean spot, just a couple aligator clip jumper wires should do, make sure the battery ground is bonded to the block and the block to the body, i had a bad ground that acted like that
