In need of a LSA swap parts list
Jokerzl
Forum Sponsor
3,635
16
Ashkum
Picked up a g8 gt 2009.5 for $16,000
Ok. To make sure I have the list correct I need the following:
ZL1 Blower
ZL1 Lid
Throttle Body
CTSV/ZL1 Rails
Injectors (ID1300)
Upper Pulley
Lower Pulley
Idlers
Relocation Bracket
Coil Pack Relocation Kit
Vadder Heat Exchanger
Aldo Welds Ice Tank
Trans cooler
89,596
https://docs.google.com/spreadsheets/d/18iqgi3FT9WLOunC1nYtXLziUW-liYkk4cMShY6PljX8/edit?usp=sharing
pn# part quantity
19303635 supercharger 1
19180859 bypass valve & bolts 1
12622236 ZL1 lid 1
12639188 evap solenoid 1
12603916 harmonic balancer 1
12557840 balancer bolt 1
12606501 idler bracket 1
11588727 idler bracket bolts 3
12606031 idler pulley 1
11518630 idler pulley bolts 2
11900254 idler bracket bolts 1
1260632 idler pulley 1
12606500 tensioner bracket 1
11588749 tensioner bracket bolt 2
11588742 tensioner bracket bolt 1
12622452 s/c tensioner 1
11588753 tensioner bolt 1
12636227 stock s/c belt 1
19180613 LSA intake manifold gasket kit of 2
12612467 intercooler insulator 1
11588718 s/c bolts 10
12605222 cts-v fuel rail 1
22912576 lsa fuel rail adapter 1
heat exchanger 2012 gt500 1
bosch I/C pump w/harness 1
25887797/226697069 cobalt filler neck 1
15076936 cobalt filler cap 1
  • LSA Supercharger Swap Parts.pdf
107,589
Old thread bump as I need to start gathering the misc shit I need. Hoping some of you may be able to help out. I see the spreadsheet that Yaj Yak Yaj Yak posted, just wondering if all that extra shit is needed. Have some questions below, parts I have and parts I know I need to order. So I'm asking if the spreadsheet is accurate and what else is needed? I know I can google some of this shit, but prefer to hear it from someone who has been there and done that from TCG
Will my fuel rails not work with the LSA? I have nice Holley black fuel rails
What plugs should I run?
Will my water pump and AC work, I'm running F Body accessories, and ordered a kit for a F Body
Is an ice box a must have being its just to have fun from stop light to stop light?
Same question with a trans cooler?
Parts I have and need to order
ID1050 injectors
Fuel pump, fuel filter and regulator
LSA heads with gaskets
Throttle body (NEED TO ORDER) what size for a stock blower, 92mm?
Boost district LSA kit includes below
  • Lower LSA supercharger Brand new with 1 year warranty
  • Supercharger Snout
  • Bypass valve
  • Intake manifold gaskets
  • SUPERCHARGER ZL1 LID
  • OEM LS9 fuel rails
  • Heat exchanger
  • Heat Exchanger pump
  • Throttle Body Harness/Holder
  • IAT Sensor
  • IAT Breakout Harness (if necessary)
  • Head Adapter Plates
  • BELT DRIVE ADAPTER KIT (Uses your serpentine drive)
Reactions: Yaj Yak
107,589
Definitely should run a trans cooler.
What power goal and fuel are you targeting?
Okay, I'll get with Carl@Redline Carl@Redline and daturbosix daturbosix and see what they recommend on the trans cooler as they did my trans.
Id be happy with 550-600whp using the 2.45 pulley. I was on the fence between corn, pump gas or flex.
I'm sticking with pump gas. Just dont feel like dealing with the headaches of corn for a car thats just stop light to stop light fun.
Dont get me wrong, I know the pro's outweigh the cons of corn as I have ran corn before. But its not needed with this build.
Ive also talked with 3 very well known tuners and they feel the same with what I'm looking to do.
Reactions: Bob Kazamakis
89,596
pn# part quantity
12622236 ZL1 lid 1
United States Meme GIF by Bespoke Motors Stl
89,596
You're welcome
im going to do the world a favor and type this out.
pn# part quantity
12622236 ZL1 lid 1
I know syP syP had a good list when he converted his Chevy SS (LS3) to an LSA
Youre Kidding Are You Serious GIF by Snowfall
Bob Kazamakis
I’m the f-ing lizard king
85,579
45,878
Joel
Nobody has any experience with these LSA's???
Looking around at the car show yesterday, saw a few boosted cars running catch cans.
I totally forgot about that and I'm assuming I need to run one as well, any recommendations?
You can get real fancy and spend hundreds or get an Amazon one for like $35.
Been fine on my ls powered vehicles.
Or fancy https://www.motionraceworks.com/products/motion-raceworks-billet-dual-port-catch-can-dual-10-an
107,589
