• 💡 Fun fact. Whenever you start a thread, TCG Mechanic 5000 (our AI bot) will reply to you to start helping. It doesn't know everything and it will struggle with more complex questions but it can get the thread going and provide valuable information. You can choose to disable it prior to submitting a thread.
Ignition timing on a big block?
Blownbyyou
3,899
4,023
Is anyone on here capable and interested in helping me set timing on 66 impala with a 409?
My dad bought this car a while back from a widow of some guy who “restored” it. But turns out he was an alcoholic who really didn’t do much if anything right.
The scenario right now is that the cam timing is set right for a stock cam (Assumed) as we just did it today IMG_1085.jpg. The ignition timing, Is really jacked up and we can’t figure it out. To put it in perspective at idle the timing mark on the balancer is lighting up at 12 o’clock vs 2 o’clock where the timing mark indicator is (hope that makes sense).
Anybody have true knowledge/skill set to help? Or at least point me in the direction of someone who can do it?
daturbosix
HNIC @ GoodFellas Garage
16,459
15,456
Jeff
409 in 1966? nah.
if cam timing is correct, then set at TDC on #1 cylinder.
- drop distributor in with rotor pointed towards #1 cylinder
- the closest plug wire to where the rotor is lined up is #1 now.
- 18436571 in clockwise direction on the cap from there
- snug up the distributor hold down, but still be able to turn the distributor
- start cranking it and moving shit until it fires, then jump on the light
-depending on specs of the engine, id say 30 degrees advanced(total) would be a good starting point
Blownbyyou
3,899
4,023
409 in 1966? nah.
Sorry its a 402, dont know why i typed 409 lol.....
The car is in countryside (near la grange), whats weird right now is the rotor is pointing to cylinder 2 and running fine @ idle lol...
We know 0 specs on the engine lol..
IceCreamAssassin
When in doubt, throttle out
12,578
17,178
Cary
409 in 1966? nah.
- 18436572 in clockwise direction on the cap from there
Fixed
I’d check and make sure all those wires are in the right place. Also when it’s idling throw a vacuum gauge on it to make sure you have full vacuum and not leaks. It’s also a great way to set a good base timing. Just turn the distributor slowly till you have reached peak vacuum at idle for a good starting point.
Mr_Roboto
25,920
31,098
https://www.youtube.com/watch?v=RENhHI9n65I
Go buy a piston stop and establish TDC. I think the Comp one I have was $15ish.
You probably have a mix of early pointer (which was located at 2:30 or so till 1969) and late balancer (which was located at 12:00.)
http://www.crankshaftcoalition.com/wiki/Timing_tabs_and_damper_TDC_lines_SBC
The pre-1969 damper has the TDC line on the outer ring at the 2:30 o’clock position- or 2º before the keyway centerline- i.e. the line is to the LEFT of the keyway, looking at the front of the damper or engine. The keyway is seen in the ID of the damper nose. Includes a majority of the 2.30" small journal main engines and the 1967-69 2.45" large journal engines.
The damper used from 1969 to about 1995 (some 1978-86 GM automobiles do not use the 2 o'clock position balancer and associated timing cover where there is some overlap usage e.g. G-series vans which retained the 2 o'clock balancer while the passenger car and C/K light duty trucks transitioned over to the 12 o'clock position which used a centrally located timing pointer spot welded) has the TDC line at the 2 o’clock position- or 10º before the keyway. You'll find that aftermarket dampers are the 10º type, as are the bolt-on tabs sold by the aftermarket, unless they're adjustable. The 2 o'clock position was reintroduced during the 1987 model year trucks with the 8" balancer (only with the LO5-optioned 350/5.7L).
Blownbyyou
3,899
4,023
THANK YOU! I am thinking this is why all the numbers are way the eff off. If the pointer and the balancer dont match then no one knows what the fuck is going on lol!
I told him to order a new balancer and pointer and will reply with findings..
i set gears at dot to dot, then crank engine over till #1 intake is closing then with cut down clothes hanger or other simple rod hold against piston as someone turns crank with wrench till piston comes all the way up(slows down as it hits tdc.
Also one handed use a starter button and crank till compression pushes finger off plug hole and then creep up. The timing mark should be at/near tdc.
Most big blocks I have tuned under 11-1 we have good gas and I generally set 14deg up to edge of timing tabe which if right is usually about 18deg. On HEI I make sure to piggy back new 12 guage wire from firewall connector to HEI plug. I just remove bulkhead connector, remove wire from connector. If I have spare 52 series connectors I will simply remove braided covered resistor wire and install new IGN wire, If customer doesnt want that terminal removed and folded back I also open strain relief tabs, with cleaned terminal and some liquid flux Ill lay my 12 ga wire under strain reliefs and solder it on top of the crimps. Push that black gooey crap back around and tape wire to the harness or few small zip ties depending on length of time it may stay HEI.
New HEI plugs are available everywhere.
I always crimp as solder electrical stuff.
On street engines with moderate cams STOCK HEI weights with lightest springs in Accel kit or MSD kit works well. Make sure the centrifugal stop bushing is present on bottom stop pin of distributor. 14-18 initial and the light spring generally give best road performance w/limited track. Listen for spark knock, starter buck.
After setting timing and adjusting carbs idle mixture and speed, THEN hook vacuum advance up to manifold vacuum. and readjust final carb adjustments.
This generally gives you proper off dyno starting place. If you get spark knock, hard surging or starter buck pull 2 deg initial. If you total goes past 55-58 you have distributor stop bushing issues or long travel vac advance. or possibly the vacuum advance can is adjustable for maxlength through vac hose port.
Again I like 53-58 MAX advance at 2500-3000 vac advance hooked to manifold vacuum(revs up engine and timing goes up) What vacuum advance is for is mileage. and you want it to DROP when you open throttle.
In car way to dial in initial and centrifugal is start at 14 and advance 2 degrees till it bucks starter hot, back off 4 deg. This is base and can be tweaked as needed.
Centrifugal advance needs to be in BY CRUISE RPM IE 55mph=2800 or just below. or what ever your final gear gives you at 55mph.
Then adjusting mechanical/centrifugal max with stop bushing. and mixing and matching springs, I sart tose with both lightest then swap in on light one medium, then two medium etc. BUT best seat of pants/track time dial is a working from their.
Adjusting max mech advance and initial for best 60 ft/ET. Street cars can keep vac advance line on as open throttle negates it if vac adv spring is good.
Some cars with lumpy cam racing needs vac line removed and plugged.
