How to make a Terminator Cobra better......
03GTGreen
Cobra Brigade Presidente
Drive by wire sucks, so much lag in the pedal feel
98GrandPrixIraqVet
Nowheresville North Dakota
That depends on tune and they make pedal boxes that make the signal more sensitive.
Makes me wonder if they could make a 10 speed work in a Termi Cobra!?
Now that'd be badass!
Pressure Ratio
Glen Ellyn
I wouldn't agree with that in the coyote I have driven. My BMW is excellent with it. It is something that can also be easily fixed with a tune.
Plus so much more you can do with drive by wire. Power management with traction control, throttle closures to help boost response, keep turbos spooled, throttle pedal % to throttle blade angle rates, and so on.
1quick
coal city
There is zero lag on any of the newer drive by wire coyotes I’ve had, I remember when it first came out the f150’s were horrible
GTPpower
Nebraska
My first DBW was a 04 F150. I could punch the pedal to the floor, release it, and nothing would change. I was able to decrease it some with HP tuners, but it was still really bad.
98GrandPrixIraqVet
[MENTION=10105]GTPpower[/MENTION]
By context that 04 F150 is 15 years old......
DBW and computers capabilities are far better now.
Comparing coyote computers to an 04 F150 doesnt make much sense.
Why do you think they switched the 03/04 whatever year termi that is to use a coyote computer?
Obviously its far more capable than what it came with in 03/04....
Again using a STOCK OEM computer on an older car and reteofitting it all to work truely impresses me.
No mega buck Holley EFI or AEM engine management needed here!!
Next step I believe is going to be Transmission tuning especially with the next GT500 going DCT transmission and even stock GM/Ford 10 speed tuning can make a massive difference.
GTPpower
Nebraska
Yeah, I know what you mean. It has greatly improved. I have no complaints about it on our newer vehicles. I was just stating how terrible it used to be.
Kensington
I'm just assuming he tuned the Coyote PCM with the 4V firing order?
98GrandPrixIraqVet
Huh? Its the same isnt it? Just the Voodoo firing order is different due to flat plane crank.
Cross plan crank coyote and modulars would be the same I think?
:thinking: Thats a good question.
Honestly easy enough to rearrange the cos too LOL!
Kensington
03GTGreen
I would agree with you but i am exempt from tuning(for now) and refuse to buy the $300+ pedal commander
Therefore it sucks....rev matching for downshifts...there is so much delay
I could be use to the 01 though
Pressure Ratio
Glen Ellyn
Could be just accustomed to the 01. It could be the factory tuning. But seeing as I have never read any review that said it was an issue with the car, I wonder.
Are you downshifting at like 5,500 rpm or are you downshifting at 1,500 rpm? Because that motor is a little "lazy" below 4,000 rpm, I wonder if it is just the rpm at which you are downshifting at? Do you know what I mean?
Fish
From the mean streets....
Chiraq
So make it an automatic. Half of TCG.......automatically.....hates it now. :s00ls:
IZZy
Powered by ES
You can’t. Terminator’s level of awesomeness is too much as is:s00ls:
