how many Hp & tq???
Blood on Blood
rumble baby rumble
Apr 6, 2005
56,820
46,646
ILLINI-SVT said:
Numbers below were with a Bassani, Steeda intake, 2.8 and RWTD tune, on a Mustang dyno. I didn't think the 2.8 was that different, unless it's because of the Mustang dyno???
Someone else can chime in, but I was informed a Mustang Dyno reads approx. 10% less rwhp/rwtq as than a DynoJet.
Each car is different as with each dyno. Heck, a dyno might not even be calibrated correctly.
A dynos number #1 purpose is for tuning, then the rwhp/rwtq numbers are a added bonus. What matters is what the car does at the track.
Dave
doodad
1,061
erdal... you should be fine with the tune.. just throw it on a dyno to verify a/f..
as far as mustang dynos, i tuned 15 cars this past weekend in Indy on a mustang dyno and it read 10% higher then a dyno jet.. its all in the calibration...
will do sir.
i just got back from track. 11.88@119mph w/ 1.75 60'
air sucked because it was around 2400ft above the sea level.
can anybody calculate the D/A for today at 6pm for union grove, WI?
thanks.
gnxs
Electron Powered
Apr 26, 2004
8,930
256
doodad said:
will do sir.
thanks.
The DA was 1959 at 6PM, based on this info I found and plugged into a calculator:
Track Elevation - 715 feet
Temp - 76 degrees
Dew Point - 45 degrees
Barometer - 30.05
doodad
1,061
Temp - 76 degrees
Barometer - 30.05
THANKS. Iguess my time is ok according to almost 2000ft D/A.
I looked for you after my first run Larry but couldn't see you anywhere. How did you do?
It was very nice to meeting you and thanks for the advice:)
gnxs
Electron Powered
Apr 26, 2004
8,930
256
I've been having shifting issues since the new trans went in (I still suspect it's the clutch). On my 2nd pass I couldn't find 2nd.....twice, so I figured I wouldn't waste my time making any more passes until I get this issue figured out.
Nice meeting you Tuesday. Keep at it, you'll get where you want to go. Practice, Practice, Practice. :biggthump You've got an 11.6 or so in it just by getting your 60 ft. down to where it should be with those tires...which is the 1.5's.
JA$ON
ching chong potato
Sep 7, 2004
17,332
There was racing at the track and I wasnt invited, cmon Larry, give a brotha a courtesy call..... :D
gnxs
Electron Powered
Apr 26, 2004
8,930
256
Actually I had you in mind, but after what Victor and Carl said you went through last trip to GLD, I figured you wouldn't be going back right away.
It was a last second decision, but I should have dropped ya a line. Sorry Jason.
I think I'm more frustrated with my shifting issues than you are breaking parts.
JA$ON
ching chong potato
Sep 7, 2004
17,332
yeah, my skinny is still stuck on my car.... :(
i was just giving you a hard time :D sorry to hear of your trans/clutch issues, i wouldnt be real happy either after putting that trans in there
Dragon03
Super hated on
Mar 28, 2007
27,350
:spaz: :spaz: :spaz:
Dave
Yep awhile ago after a prior dyno with my car on a dynojet it was around 446hp i went to a different shop had some other stuff done and she put down 422hp i almost had a heart attack because i thought the guy killed my car :spaz: :spaz: :spaz:
doodad
1,061
Yeah the car has 11.6s in definetely. I honestly think i can run even 11.5s with better 60' and cooler air. (I always aim high:D) Air kinda sucked but we won't see any better all summer. I am sure right before the seasion is over around fall, i will run low 11s. i have a couple mods in mind and 0ft or - D/A will help a alot.
I wanna launch it hard and cut some good 60' but i just don't have big enough balls for that. Even though you said that i wouldn't break unless i hop, i still launched at 3k RPM:D if i would have trailer around, i would definetly cut a lot better 60'.
sorry to hear about your shifting issues, I hope it will get better soon.
