Looks like I blew a CV boot.
Whats the best course of action TCG?
I noticed while installing the HID fogs tonight....
easy as pie, as long as u have the big socket
I want the hook up!
i would pop the 2 strut bolts off instead of trying to get the ball joint to come loose. that's just me though....
Retarded of NAPA, but thx anyways.
X2; remove axle nut, remove wheel, pop lower ball joint, swing knuckle out enough to get shaft out.... and reverse... took me an hour with only hand tools, will go faster with air tools
do u wbody guys have to pull ur tie rod end out of the hub to get the axle out as well?
not that i know of..... pop the ball joint, turn wheel twards that side of car and there should be more than enough wiggle room.
