You say the CID part of the formula dictates the winner. The power and torque numbers have a lot to do with the score.
Hi, my name is KJ and I have no clue what Iam talking about......
LS1
Engine Dimensions
4.6 Mod Motor
Ford modular SOHC & DOHC tech & specifications
4.6L DOHC Cobra Intake A: 27 1/8" B: 23 5/8" C: 26 5/8"
true, every aspect of the formula dictates the winner... it would be cooler imo to have the cid portion of the formula not as heavily weighted as the power and torque numbers imo
I think as well it'd be neat to raise the 7k rpm limit... keep it the same fuel and the compression the same, let these engines sing.
fo real?
I thought this is what was going on...
I think they have to or everyone would be building 700 CI monsters.
what is it?
I think the rpm and comp ratio are BS. Keep everything else the same and let those go. If you want maybe limit the octane rating of gas, that should help keep the ratios a little lower.
but who wouldn't want to see a 500cx lsx or mod motor
No mod motor can be made that big. Not enough bore and stroke with the current architecture.
Why do you say that? This is the first time the motor was used with good results. Chevy and Mopar motors have done very well in the past.
